Thread: bad starting and misfiring
Results 1 to 10 of 11
  1. bad starting and misfiring
    Apr 2015
    Brighton East Sussex
    got a superb 1.9 tdi 2010 it has difficulty starting on initial start up after about a mile driving it starts fine then when fully warmed it doesn't like to start it tries to but won't get going have to crank it over about 10 times before it start also runs really rough until I give it a bit of gas and I get an occasional misfire on idle
  2. Re: bad starting and misfiring
    Aug 2011
    Meath
    Get a diagnostic scan
  3. Re: bad starting and misfiring
    Apr 2015
    have had a scan done by my mobile mechanic nothing showing on his scan tool
  4. Re: bad starting and misfiring
    Aug 2011
    Meath
    What did he scan with? VAG cars don't always work well with OBD scan tools, has it had a fuel filter recently?
  5. Re: bad starting and misfiring
    Apr 2015
    he used a snap on scan tool
  6. Re: bad starting and misfiring
    Aug 2011
    Meath
    Has the DPF light been on, does it regenerate? Has it had any work done recently?
  7. Re: bad starting and misfiring
    Apr 2015
    don't have a dpf on this model I'll get another vag scan done
  8. Re: bad starting and misfiring
    glasgow
    35 Post(s)
    drive the car to a quiet bit of road, drive the car in 2nd gear for a few hundred yards and keep the revs hard down to just under the red and blast out all the crap in the exhaust. You need to do this once in a blue moon.
    Also change the diesel filter
    When you turn on ignition, always wait for the glow plugs light to go out before starting. It sounds like the glow plugs have gone
  9. Re: bad starting and misfiring
    Apr 2015
    wouldn't a glow plug come up on diagnostic check and I give it a good thrashing occasionally anyway as its a cab and needs clearing out now and again thanks
  10. Re: bad starting and misfiring
    Apr 2015
    it is showing poor fuel delivery on injector 2 and very bad delivery on injector 4 so think I will have to change injectors
  1. bad starting and tick over
    By ollli in forum Ibiza - Cordoba
    Last Post: 18-07-2011, 07:10 PM
  2. Please Help Bad starting T5 130
    By redhot in forum The Commercial Range
    Last Post: 24-05-2010, 09:22 PM
  3. Please Help caddy van bad starting
    By carlyp in forum The Commercial Range
    Last Post: 02-12-2009, 08:09 PM
  4. what temp sensor causes bad starting
    By choppermark in forum Golf MK3 - 1993 - 1999
    Last Post: 16-11-2008, 05:04 PM
  5. bad starting polo
    By bogdan191084 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 08:43 PM
