Thread: Caliper torque spec and brake line upgrade
  1. Caliper torque spec and brake line upgrade
    Apr 2015
    Midlands
    Hello
    I'm going to remove my calipers and overhaul. Much appreciated if someone could provide me with bracket to hub and caliper to bracket torque spec. I have the larger calipers - 188mm pads with 320mm disc.
    Also want to upgrade the brake lines to stainless. All the suppliers seem to be USA based ? Are there any UK based companies out there ?
  2. Re: Caliper torque spec and brake line upgrade
    Ardfern
    8 Post(s)
    I can't help with the torques, but wonder what is wrong with kunifer brake lines? How long do you expect to keep this car? Is it a cosmetic thing? If so, lets be seeing this car please.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  3. Re: Caliper torque spec and brake line upgrade
    Apr 2015
    Midlands
    Pic of car below its an 09 sline quattro in dark grey with the V6 petrol. Also attached pic of the brake caliper when I did the brakes (they need a coat of paint I think!). It's the rubber lines I want to replace from capiler to rigid line. Noticed the passenger side is weeping at the crimp! Thought I may as well upgrade to stainless whilst replacing which should give better feedback? For a car with 265hp the brakes are shocking!!
  4. Re: Caliper torque spec and brake line upgrade
    Ardfern
    8 Post(s)
    Now I understand. Stainless braided flexible hoses are probably a good plan however, would you not think of upgrading the calipers if the brakes are so shocking,
    and do the hoses to fit the upgraded calipers?
    Lotus Elan SE 1991
  5. Re: Caliper torque spec and brake line upgrade
    Pembrokeshire
    22 Post(s)
    what pads are you using when you say the brakes are shocking.
  6. Re: Caliper torque spec and brake line upgrade
    Nov 2013
    Cumbria
    Brakes on the A4 can be vague (from my experience!). When did you flush the brake fluid last ?
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  1. 07 T5 Rear Brake Caliper Torque Values
    By sti5300 in forum The Commercial Range
    Last Post: 18-03-2014, 09:49 PM
  2. Brake disc & caliper torque settings
    By ChA6dders in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-11-2013, 09:44 PM
  3. Question A4 S line B7 Cab Brake upgrade
    By Nagasaki in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-10-2011, 10:25 AM
  4. Brake caliper torque settings
    By maxmc2 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2011, 07:21 PM
  5. Question 1998 A4 axle bolt torque spec
    By rkalajian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-09-2009, 12:10 AM
