Thread: MK4 130 TDI rattle/clunk from front
  1. Question MK4 130 TDI rattle/clunk from front
    Aug 2008
    High Wycombe
    Hi Everyone
    Been a member for some time but have not posted for a few years so i may be a bit rusty here!
    I have a MK4 GT TDI 130 (2002 reg) that I have owned since new. Runs great, the same as it did the day I bought it! Recently it has started to make a clunk/rattle noise from the front end
    I have taken it down to my local garage that I know and trust very well, the guys have had it on the ramp for almost two days and cannot find what is making the noise. All the bushers look fine and so do all the joints (so they tell me)
    It doesnt happen over bumpy surfaces, and if i bounce the car by pushing down on it - no issues at all
    The guys at the garage say maybe its the gearbox but they cant be sure and I think there clutching at straws now! It honestly drives with no issues, picks up like a train, gear changes are normal, doesnt stick or struggle to go into a gear at all
    Just wondered if anyone had an ideas on what it could be? Or if anyone could recommend a garage down near High Wycombe where I could take it to get it checked out?
    Appreciate any help on this
    Kam
  2. Re: MK4 130 TDI rattle/clunk from front
    Pembrokeshire
    22 Post(s)
    so when does it clunk from the front . you say its not doing it on a bumpy road, so knowing when it does it might help. maybe ??
  3. Re: MK4 130 TDI rattle/clunk from front
    Nov 2013
    Tullamore, Offaly, Eire
    Could be the bump stops in subframe or that connector between engine and frame that looks like a dog's bone are worn ?
  4. Re: MK4 130 TDI rattle/clunk from front
    Aug 2008
    High Wycombe
    Hi Guys
    Thanks for the replies. It seems to be random when it starts to happen. At slow speed or high speed - makes no difference. It doesnt matter what gear the car is in (even if it is in nuetural), or if its accelerating or slowing down
    The guys have said they have checked the engine and gearbox mounting and they seem fine. If it helps, I think the noise is coming from underneath the dashboard?
  5. Re: MK4 130 TDI rattle/clunk from front
    Nov 2013
    Odd place for a rattle clunk imho.. spend 20 quid on a Haynes manual for her and see if you can get some of the centre console out easily and see if anything moves maybe? I've a mk4 myself that clunks despite being checked but tbh that's the least of my concerns with her.
  6. Re: MK4 130 TDI rattle/clunk from front
    Liverpool, UK
    First place to check - front top mounts. They're renowned for going and causing all kinds of bumps and knocks.
    Don't cost that much new and it's an easy'ish job to change them over.
    Next on the list would be the wishbone bushes. Though if they've been checked with a pry bar then you could rule them out.
    Tabs
    2013 C7 A6 Allraod with a few toys
    2003 Bora 2.0T Track Car
  7. Re: MK4 130 TDI rattle/clunk from front
    Aug 2008
    High Wycombe
    Hi Tabs
    Spot on!! Changed the top mounts and that has sorted me out 100%
    Thanks for your help on this one - had a lot of people baffled!
    Kamran
  1. Rattle/Knocking from Front Susp on MK4 Golf
    By jrwilshire2003 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2015, 09:12 PM
  2. rattle/vibration when driving in 4th gear, 2002 Golf 130 TDi
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2012, 10:54 PM
  3. Question Rattle Clunk sound from gear box when changing gear?
    By jasonocallaghan in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2008, 12:20 AM
  4. 1998 a6 tdi front RATTLE & knocking
    By shorty in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-11-2007, 02:06 PM
  5. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
