Thread: Emissions Workshop Engine Management Light
Results 1 to 10 of 10
  1. Emissions Workshop Engine Management Light
    Jul 2014
    Southampton
    I am guessing this has been posted before but i couldnt find any specific relation to my car.
    I have a 2005 Passat B6 2.00 TDI Sport
    Had the engine management light come on a month ago with the glow plug symbol flashing but only intermediately not every time i drove the car so i went to the garage who done some diagnostics and come back with the following fault codes -
    01412 - Glow plug with flame control system Q8 not a plausable signal
    19557 - Motor for intake manifold flap (v157) open or short to ground
    19559 - Motor for intake manifold fla0 (157 no signal
    17057 Cylinder 3 glow plug circuit (Q12) electrical fault
    17075 - Fan 1 control circuit short to ground
    they advised to replace all glow plugs and intake manifold.
    I replaced the intake manifold myself but not the glow plugs, a friend done some diag cleared the faults.
    The glow plug symbol never flashes now but the engine management light still comes on and the emissions workshop warning still appears on the dashboard.
    Now the diag only shows the short to ground fault on the manifold flap and the fan 1 control circuit.
    Any suggestions?
  2. Re: Emissions Workshop Engine Management Light
    May 2007
    17 Post(s)
    Quote Originally Posted by djkinetix250 View Post
    The intake manifold...surly not?
    OH NO!
    DOOH!
    Any suggestions?
    Yeah. Check the fuse that supplies the manifold flap actuator. There are two possible fuse locations depending on what engine you have but I've marked both on the attached diagram.
    If the fuse checks OK, disconnect the plug from the intake flap actuator and measure the voltage on terminal 2 of the harness connector. Make sure you have 12V (ignition switched on).
    Jim.
  3. Re: Emissions Workshop Engine Management Light
    Jul 2014
    Southampton
    Hey man thanks for your help.
    Checked the fuse and its fine, just checked the voltage on the harness connector and terminal 2 showed a minus figure so what does that mean from here?
  4. Re: Emissions Workshop Engine Management Light
    May 2007
    17 Post(s)
    I'd say something was wrong with the way you had your meter connected because if the black meter lead was connected to ground, you can't have a negative voltage, ie a voltage lower than ground.
    Do you know what your engine code is? I've had a look at a couple of wiring diagrams and it seems that the fuse that supplies voltage to the flap actuator depends on what engine is in the car.
    Take a look at Fuse 20 & 23 on the engine bay fusebox too. Fuse locations shown on the diagram I posted.
  5. Re: Emissions Workshop Engine Management Light
    Jul 2014
    Southampton
    Its a bkp engine code. Just checked 20 and 23 and 23 has blown so that is probably the problem :-)
    Will get a new fuse from motorfactors tomorrow and let you know if there is any further issues.
    Thanks for your help as im a total n00b at this!
  6. Re: Emissions Workshop Engine Management Light
    May 2007
    17 Post(s)
    No your not, but I'm not too sure about the tech in the garage that advised you to replace the manifold.
    I didn't just take a guess about that fuse being blown...it supplies the manifold flap & the cooling fans. The codes your garage pulled kinda tell you what the problem is likely to be.
    Jim.
  7. Re: Emissions Workshop Engine Management Light
    Sep 2008
    SE London
    Fuses don't just blow for no reason. So get two -- of the correct value
    Don't be surprised if your replacement blows.
    Don't be tempted to up the fuse's value "just to see" either. Been out to jobs like those, they're usually a mess afterward.
    Good luck
  8. Re: Emissions Workshop Engine Management Light
    May 2007
    17 Post(s)
    Quote Originally Posted by RichardSEL View Post
    If the replacement blows, the tech in his garage is defo a n00b
  9. Re: Emissions Workshop Engine Management Light
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by Flash2 View Post
    If the replacement blows, the tech in his garage is defo a n0b
    Put that right for you....
    A4 2.5 tdi QS (mapped)
  10. Re: Emissions Workshop Engine Management Light
    Oct 2010
    Windsor, UK
    I had similar issues on my Tiggy 2.0 TDI 170 with the lights coming on (glow plug light flashing and the little 'engine' symbol). I was told various implausible things ranging from DPF to glow plugs. Changed EGR and MAF sensor, seems OK now. But I'm as confused now as I was before. No idea if that helps anyone - hopefully it might.
    VW Golf GT TDi 170 MkV 2006
  1. amber engine management light, emissions garage message on dash
    By phatagrova in forum Jetta MK3 - 2005 - 2013
    Last Post: 04-08-2013, 09:27 PM
  2. emissions workshop light
    By brett1 in forum Touran - Sharan - Caravelle
    Last Post: 04-08-2010, 04:23 PM
  3. Please Help Engine Warning Light & Emissions Workshop
    By stevem61 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2010, 04:33 PM
  4. Engine management - Emissions workshop
    By mm07 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-06-2009, 10:32 PM
  5. Please Help Emissions Workshop + Engine Management Light
    By R_FLIZ in forum Golf MK4 - 1999 - 2004
    Last Post: 20-05-2008, 09:40 AM
