Thread: Low oil pressure warning!!!
Results 1 to 8 of 8
  1. Low oil pressure warning!!!
    Mar 2015
    Glasgow
    Hi guys
    I have a 2010 b8 1.8tfsi which has recently had the Pistons and con rods replaced due to the high oil consumption but I've recently noticed that the low oil pressure warning has came on twice in recent weeks after around 2 mins of starting the car. In both instances I have turned the engine off immediately. any ideas as to what could cause this? Would this be picked up by having the car scanned? Any help would be appreciated.
    Thanks Marty
  2. Re: Low oil pressure warning!!!
    Sep 2008
    Berkshire
    You didn't state if you actually checked the oil level.
    Are you driving the car for those 2 mins or is it just idling?
    A5 (Cabriolet) 2.0 TDI 177PS S-Line - Scuba blue, Technology pack (high), B&O soundsystem, Bluetooth (low), Heated seats, Autoglym life shine.
  3. Re: Low oil pressure warning!!!
    Mar 2015
    Glasgow
    Well according to the screen it's showing full. The light has came on sitting at traffic lights normally after driving less than a mile.
  4. Re: Low oil pressure warning!!!
    Sep 2008
    Berkshire
    Quote Originally Posted by Martya4 View Post
    My previous A4 occasionally stalled when first driving away after start up which was put down to low oil pressure, but that wont be your issue if you are already a mile or so down the road. Could
    be worth a scan for a faulty sensor and your rebuild should have come with a workmanship warranty if its likely to be anything more serious than that. (90 days perhaps)?
  5. Re: Low oil pressure warning!!!
    Mar 2015
    Glasgow
    I took it back to the dealership that done the rebuild and he said the scan didn't pick up anything and said it might be a sporadic fault just popped up but it's done it twice now. I'm thinking of going elsewhere to get a scan incase they're at the madam just to put my mind at rest
  6. Re: Low oil pressure warning!!!
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    A oil pressure test with a guage would be the only thing that would put my mind at ease. Yes, it could be a sensor fault, but if checks cant prove it to be faulty, insist on a guage be fited to check, both engine cold and hot.
    Alan.
    VW T6 150 DSG Camper £££
  7. Re: Low oil pressure warning!!!
    Mar 2015
    Glasgow
    The car is being taken in by the dealer today to run some tests on it So let's see what they come up with
  8. Re: Low oil pressure warning!!!
    Apr 2015
    hey, maybe you sorted that problem? I got avant 09 2.0tdi. And I got that problem aswell. Sometimes I start a car and it says low oil pressure. Checked the oil and its all good. Vag com shows nothing wrong. So yes, maybe faulty sensor or smthing
  1. Low oil pressure warning - again!
    By master220 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2014, 03:50 PM
  2. Low oil pressure warning .....help
    Last Post: 10-02-2013, 06:07 AM
  3. low oil pressure warning
    By kalarico in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2010, 10:54 AM
  4. Low oil pressure warning
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2008, 01:04 PM
  5. low oil pressure warning!!
    By w-s-m passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:46 PM
