Thread: few problems
  1. few problems
    Jan 2012
    cruden bay
    Just bought an a4 1.8t quattro on sunday. 1st off os the temp gauge is stuck on hot even when the car is off, and the second problem is ive a code p0011 you lot will already know what it is so no point on writing ot out, car still feels fine to drive, is the code serious. Thanks
  2. Re: few problems
    Jun 2012
    Wiltshire
    Possible causes
    - Dirty engine oil
    - Low engine oil level
    - Camshaft actuator circuit open or shorted
    - Camshaft actuator circuit poor electrical connection
    - Faulty camshaft actuator
    Possible symptoms
    - Engine Light ON (or Service Engine Soon Warning Light)
    Read more: P0011 Audi 'A' Camshaft Position Timing Over-Advanced Or System Performance Bank 1 OBDII Engine Light Trouble Code | Engine-Codes.com
    It can affect performance significantly or could be intermittent. I would start with the basics checking the oil checking the connection for the cam sensor. at worst I would think you need a new sensor which are not terribly expensive.
    You can test the sensors with a multimeter as I had to do so on a crank sensor (engine speed sensor) on my old A3 which took weeks to find the problem I was changing all sorts and mine didn't throw up an error.
    http://easyautodiagnostics.com/misc-index/ckp-cmp-sensor-basics-1
    Though I am no expert just a DIYer with lots of broken cars...
  1. Please Help ignition problems. Well. Let's go with just Problems to be honest.
    By j.topher in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2015, 02:01 AM
