Thread: Recommended tyre pressures 245-45/18
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    I've got a set of continental sport contract 5 on the front of my A6 2.0 TDI. I've been running them with 32 psi, mainly doing motorway miles on my own and I've noticed they are wearing on the middle of the thread as if they're over inflated. I've checked the pressures with different devices and all the trading where closer to 32 psi.
    Any advice or recommendations on what pressures to use? I'm about to fit a pair of Goodyear F1 asymmetric2
    P.S They are measuring 4mm outside and 2mm in the middle of both tyres.
    VW CC GT 177 DSG
  2. Re: Recommended tyre pressures 245-45/18
    46 Post(s)
    What are the pressures listed on the inside of the drivers door jam for that size?
  3. Re: Recommended tyre pressures 245-45/18
    Pembrokeshire
    22 Post(s)
    try 28 then. keep an eye on the depths. or use chalk dust to cover an area of tread, drive a few yards and see how it wears. adjust the pressure up and down until it wears evenly across the tread.
  4. Re: Recommended tyre pressures 245-45/18
    Feb 2013
    Gloucester
    57 Post(s)
    Have you checked against the sticker inside the drivers door?
  5. Re: Recommended tyre pressures 245-45/18
    Feb 2013
    Gloucester
    57 Post(s)
    Wife has an A5 and hers reccomends the following:
  6. Re: Recommended tyre pressures 245-45/18
    46 Post(s)
    ^ just remember pressures will differ car to car due to drivetrain, overall weight, engine size and type of body.
  7. Re: Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    It recommends 32psi, so they're bang on. The rear tyres are the original Bridgestone and they are running the same pressure as the front and wearing evenly. Thinking it may be the contis tyre construction....
    VW CC GT 177 DSG
  8. Re: Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    I'll double check the sticker on the door later. Working this evening
    VW CC GT 177 DSG
  9. Re: Recommended tyre pressures 245-45/18
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    I have a similar problem with my factory fitted Bridgestone Turanza tyres (also 245 45 18s 2.0 tdi ultra). They've always been within manufacturer recommended pressures, but both front tyres have worn down towards the legal limit in the middle after 14k miles, but have lots of tread towards the outside. Will be running my new front tyres (Michelin Primacy 3) at slightly lower pressure.
    Good tip zollaf re chalk dust.
  10. Re: Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    Good to hear I'm not the only one having this problem. The bridgestone on the rear of my car are the original and have 32k miles on them and they're just on the limit. So I'll fit the contis on the rear and hope they even out and fit the new tyres to the front.
    VW CC GT 177 DSG
  1. Increase Tyre size from 225 to 245
    By nicktooley in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-06-2013, 10:20 AM
  2. Please Help 245/45/R17 tyre deals please!
    By vwawudi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-05-2012, 05:07 PM
  3. Tyre choice - 245 40 18
    By xtremist in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-02-2012, 12:24 PM
  4. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  5. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
