Thread: Golf Mk 6 Main beam adjustment.
Results 1 to 10 of 12
  1. Golf Mk 6 Main beam adjustment.
    Dec 2007
    Hi all, I need to adjust the mainbeam (NOT the dipped beam) on my Golf Mk 6. I have asked 2 garages to do this and both have failed to so despite charging for the work. Both sides point down immediately in front of the car.
    Can anyone help please?
    Thanks in advance.
  2. Re: Golf Mk 6 Main beam adjustment.
    131 Post(s)
    1974 Post(s)
    Does the height adjuster wheel next to the headlight switch have any effect on the aim? Which type of headlights does it have? Both elements are on the same adjustment.
    1 = lateral 2 = height
    1 1 0
  3. Re: Golf Mk 6 Main beam adjustment.
    Dec 2007
    Hi, No the wheel adjustment only seems to move the dipped beam. Mainbeam shares a bulb with the driving lights and I haven't yet found the adjuster for it. I think the dealers checked dipped beam only.
  4. Re: Golf Mk 6 Main beam adjustment.
    131 Post(s)
    1974 Post(s)
    There is only one adjustment which moves the entire assembly inside all at once.
  5. Re: Golf Mk 6 Main beam adjustment.
    Dec 2007
    So mainbeam can't be adjusted independently of dipped beam? Thanks for your help so far Crasher but I am left with a puzzle - if dipped is adjusted correctly mainbeam should also be, but it is not, as mentioned both mainbeams point down to the right and immediately in front of the car giving no distance lighting at all.
    Any suggestions anyone? Has anyone had the same problem?
  6. Re: Golf Mk 6 Main beam adjustment.
    131 Post(s)
    1974 Post(s)
    Correct, the main beam aim is tied into the dipped beam aim. The usual cause of things like this is incorrectly fitted or poor quality bulbs. It makes me suspect the H15 bulb is incorrectly fitted BUT if it was, it would not work. However it IS possible to fit the H7 bulb upside down.
  7. Re: Golf Mk 6 Main beam adjustment.
    Dec 2007
    Thanks I will check the type and fittings. One other thing occurred to me while mulling this over - if the wheel next to the headlamp switch was in the fully up position when the lights were adjusted by the dealer the aim might perhaps have been adjusted down to conform? Thus the main beam would correspondingly be adjusted down (too far) does it make a difference what position the wheel is in when adjusting the aim?
  8. Re: Golf Mk 6 Main beam adjustment.
    Dec 2012
    Bury Lancs
    Is there a chance that the bulbs have been replaced with the incorrect bulbs .?
    2010 Golf 2.0 TDI GT 140 DSG , 5 door in white.
  9. Re: Golf Mk 6 Main beam adjustment.
    Dec 2007
    There is, I will be checking that too, thanks.
  10. Re: Golf Mk 6 Main beam adjustment.
    Jun 2010
    Nottingham UK
    I queried this 5 years ago when I first got my Mk6. If you are 4/5 up you need the dipped adjuster down but it doesn't move the 'full', thus the beam is up in the tree's and you have a very significant 'black spot' in the middle of your vision. Very poor design from VW on this.
  1. Main beam problem
    By expat2000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2014, 12:46 PM
  2. Dipped and main beam
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2013, 11:27 AM
  3. Main Beam Adjustment?
    By Pauls898 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-04-2012, 10:44 PM
  4. A6 Main Beam
    By stevedrinnan in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-11-2010, 09:01 PM
  5. No main beam...
    By DukesA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-03-2010, 12:45 PM
