Thread: Fans running constantly, Various Fault Codes
Results 1 to 10 of 12
  1. Fans running constantly, Various Fault Codes
    Jun 2014
    Worksop, Nottinghamshire
    Hi All,
    Just wondering if anyone could shed any light on a fault.
    When starting the engine the fans start running and continue to run until the engine is stopped.
    The only faults stored are below
    5262 - Exhaust Pressure Sensor 1 (G450)
    P0472 00 [039] - Signal too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 235139 km
    Date: 2015.03.28
    Time: 19:06:53
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 235139 km
    Time Indication: 0
    Date: 2015.03.28
    Time: 19:06:58
  2. Re: Fans running constantly, Various Fault Codes
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Reckon your g395 ac switch is causing fan to run. I think there was an audi tsb issued on these switches.
  3. Re: Fans running constantly, Various Fault Codes
    Jul 2013
    77 Post(s)
    What engine and Year?
    For the G450 fault check that the wiring to the sensor is Ok, It could be a Hole in the exhaust or it could be the sensor or ECU.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  4. Re: Fans running constantly, Various Fault Codes
    Jun 2014
    Thank you, I didn't want to replace the sensor if it was going to be something different. Will try this and see what happens.
    Is the G395 sensor - 4H0959126?
    Its a 2010 - 2.0TDie SE.
  5. Re: Fans running constantly, Various Fault Codes
    Jul 2013
    77 Post(s)
    The DPF sensor on your car is at fault for the G450 error, now that you posted up an engine code I had the same issue on a friends 2010 2.0 Le Mans back in January 2014.
    P0472 00 [032] - Signal too Low
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 191313 km
    Date: 2014.01.19
    Time: 06:36:33
    The Sensor (059 906 051 A) back then cost £60 from TPS.
    It takes around 20 minutes to change as you will need to remove the Fuel filter holder to gain better access to the hose pipe clips.
    Also get a can of compressed air if you don't have a compressor to blow back hoses before fitting the new sensor, then you need do an adaptation using VCDS once fitted.
    Google SSP 420 for your engine.
    The G395 sensor can be 4F0 959 126 C for up to 01/2010 and 4H0 959 126 for after 01/2010.
    Dan
  6. Re: Fans running constantly, Various Fault Codes
    Jun 2014
    Hi Dan,
    The engine code shown by VCDS is (SK10YPC - Engine (J623-CAGB)), don't know if you could get the sensor part number for this?
  7. Re: Fans running constantly, Various Fault Codes
    Jul 2013
    77 Post(s)
    They are the same sensor (g450).
    The sensor number is posted above.
    Known for giving trouble.
    Dan
  8. Re: Fans running constantly, Various Fault Codes
    Apr 2015
    romania galati
    This sensor is Temperature sensor before turbocharger? i have there on it a temperature of 849.6C with cold engine. i think its down, and my fans also work permanently
  9. Re: Fans running constantly, Various Fault Codes
    Jun 2014
    The fan problem we had cured after replacing the sensor.
  10. Re: Fans running constantly, Various Fault Codes
    Apr 2015
    romania galati
    You have a photos of this sensor?
  1. Fans on constantly with AC
    By Fred Thornton in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2014, 05:35 PM
  2. Please Help Aircon Warm and both Radiator Fans inop. with fault codes.
    By VEEDUBYA in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-07-2011, 09:39 AM
  3. Bad running followed by fault codes
    By Grant620 in forum VCDS - General Questions
    Last Post: 05-11-2010, 12:00 AM
  4. Should these fans run constantly?
    By Homebuildbloke in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-07-2009, 01:26 PM
  5. Please Help 2003 S4 (B6) fans running constantly
    By adamjwk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2008, 12:26 AM
