Thread: gearbox issues
  1. gearbox issues
    Mar 2015
    southampton england
    Hi all,
    Just before Christmas I had the main input shaft bearing fail in the gearbox. I was quite lucky as the casings hadn't been damaged and all the internals looked fine. At the same time I had the clutch replaced as it was on its way out, I cannot remember if we replaced the flywheel, I'm pretty sure we didnt. The gearbox felt perfect after that, almost like new.
    5,000 miles and a 3 months later the same problem has come back, additionally some of the gears themselves seem to have become a bit loose and clicky. Not just the sound of a grinding bearing anymore.
    Should I be looking at replacing the entire gearbox and or flywheel or try and fix the gearbox again.
    I use the car as a works horse so I constantly have weight in the boot and often ladders on the roof so the gearbox comes under a lot of strain. Car has done 105,000 miles now.
    Passat 2.0 tdi b6 estate.
    what 6 speed boxes would be a straight swap ? I wouldn't mind a slightly closer ratio box if I came a cross one in good condition at the right price.
  2. Re: gearbox issues
    Mar 2015
    southampton england
    Also, un-related, I have an intermittent flat spot at high revs when under load. Typically 3rd and 4th gear. Thinking it could be fuel pump on its way out? Or injector fault?
    I ran some fuel treatment and a few full tanks of v-power and the problem seems to have gone temporarily. Anyone else had this issues?
    Regards
  1. hello..gearbox issues
    By Phil wilson in forum New Member Introductions
    Last Post: 21-11-2014, 09:42 PM
  2. Gearbox issues
    By vc-10 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2014, 10:18 PM
  3. Gearbox Issues
    By warrenm14 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-10-2012, 04:02 PM
  4. Gearbox issues
    By e6m6a6 in forum Octavia
    Last Post: 25-09-2011, 02:26 PM
  5. gearbox issues
    By volvofh in forum Golf MK5 - 2004 - 2009
    Last Post: 09-02-2011, 10:10 PM
