Thread: PLEASE HELP - A4 B6 Cabriolet 2.5TDI Cruise Control Retrofit & VCDS
  1. Unhappy PLEASE HELP - A4 B6 Cabriolet 2.5TDI Cruise Control Retrofit & VCDS
    Mar 2009
    Poole
    I am hoping someone can help me .... please!!!
    I have fitted the steering control module below, and am having problems coding it to my car.
    ABS, STEERING ANGLE ETC.
    Is the module below compatible with an A4 B6 Cabriolet ?
    The module is from an A4 B7 Cabriolet.
    I am also struggling with VCDS, I found it easier to use on my A4 B8, but really struggling getting my head around it for the Cabriolet.
    t.
  2. Re: PLEASE HELP - A4 B6 Cabriolet 2.5TDI Cruise Control Retrofit & VCDS
    Mar 2015
    Estonia
    Hi!
    Did you get any help? Installed exact same module from B7 Cabrio to my B6 saloon few months ago, so i can't see reason why it shouldn't work. Now the tricky part. Did you perform full auto scan with VCDS and saved it before replaced module? If not, then brake coding need to figure out. Now you have brake coding 00000, isn't it? Do you know what is your car brakes PR-Code? Also car don't recognise new module(VIN fault code) in 16-Steering wheel? There is some actions that need to do in correct order. If not then fault codes not clear. If you get done with this, it's great. If not, then better send me your email, cause this would be quite a lot of writing.
  3. Re: PLEASE HELP - A4 B6 Cabriolet 2.5TDI Cruise Control Retrofit & VCDS
    Mar 2009
    Poole
    Good evening, thank you for getting back to me.
    Fingers crossed, i think its all sorted now :-)
    I was coding the wrong brakes!!!!
  4. Re: PLEASE HELP - A4 B6 Cabriolet 2.5TDI Cruise Control Retrofit & VCDS
    Mar 2015
    Estonia
    Glad to hear that you sorted this out. Full autoscan saving to log would be great thing to do if you replace modules. Save a lot of time for coding. Ask me how do i know .
  1. Cruise Control Retrofit
    By OldBoy Racer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-08-2012, 08:34 PM
  2. A6 2.0tdi 2004 board comp & cruise control retrofit
    By kiki_vz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2011, 04:34 PM
  3. Cruise Control retrofit
    By Nbaddy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 10:21 PM
  4. Retrofit cruise control
    By racman5487 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-07-2009, 11:44 AM
  5. Cruise Control Retrofit
    By Greenfield in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2008, 12:59 AM
