Thread: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
Results 1 to 9 of 9
  1. MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Mar 2015
    United Kingdom
    Hi All,
    Finally got round to registering, though i've been on this forum for some time for hints tips etc.
    I could really do with some help on this, it has me baffled and im struggling to work it out.
    As mentioned i have a 1.9 TDI (105bhp) BKC engine Mk5 Golf, it feels underpowered, as ive driven several of these mk5 1.9 tdi's and i know what sort of power it has. Though the turbo does kick in, it doesnt feel quiet enough.
    When the car is driven to around 60-70mph, it normally goes into limp mode. Sometimes it can happen before reaching 60-70mph, but on average it normally occurs at the speed. Also, the ESP light comes on shortly after. Although, i have had the ESP light come on before it goes into limp mode aswell. Switching the car off and on normally gets the car to reset both limp/esp light, but within 5 minutes it reoccurs.
    I must also mention i have an issue with my brakestoo, after a few quick pumps it goes hard. (Ill get back to that below)
    I have plugged in VAG COM nothing significant showed up (unless ive overlooked something, the vag com reading is below), so i set about trying to eliminate all possibilities.
    I started with the vacuum pump, which was weak and i had hoped would resolve both the brakesand the turbo issue, thus i replaced it and unfortunately it did neither.
    Brakesfault is now diagnosed as independent and likely the brake servo, which im not looking forward to doing/getting done.
    So i left the brakesfor abit and thought id attempt to address the turbo/limp mode issue.
    Luckily, i had done a friend a favour, he owns a 1.9 TDI (BKC) Audi A32005, and i basically used his car as a donor to essentially apply trial and error with his parts.
    I tried the following.
    1. MAP Sensor
    2. Boost Pressure Sensor
    3. Not sure what its called, i think its called the vacuum solenoid valve (Black block)
    4. As mentioned the Vacuum pump was replaced
    5. Boost pipe
    None of the above resolved the issue, so then i looked at the actuator for the Turbo, and it didnt seem to have free movement, nor a full range of movement, was convinced it can only be that, so i went out and replaced the turbo itself as i was just getting fed up.
    Drove it and made no difference. Same issue.
    There are no air leaks that were found. I just want to make it clear, im by no means a mechanic, the turbo was changed by a garage as i dont have access to a ramp, anything that can be replaced without a need for a ramp i tend to have a go at myself.
    Today, i sprayed some Wynns EGR Cleaner into the air intake, but made no difference. I have noticed a bit of black smoke when the car is revved hard, but nothing out of the ordinary.
    EGR replacement next? or is it pointless? Has anyone experienced the same issue, i would love to hear from you. I promise if i do get to the bottom of this, i shall update this post. There is nothing like reading a thread that has no end.
    I bought vag com recently and i have not really got to grips with it properly yet.
    Vag com reading is below. Yep, i need to change the glow plugs, not got round to doing that yet, just want to resolve this issue first.
    Monday,09,March,2015,16:54:35:52368
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    Mileage: 194790km-121036mi Repair Order:
    Mileage: 194790km-121036miles
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 B HW: 028 101 147 8
    Component: R4 1,9L EDC G000SG 5645
    Revision: 12345678 Serial number: VWZ7Z0D9742950
    Coding: 0000071
    Shop #: WSC 00000 028 00001
    VCID: 224DB17EFD036131584-8077
    5 Faults Found:
    18049 - Please check DTC Memory of A/C Controller
    P1641 - 000 -
    Freeze Frame:
    RPM: 882 /min
    Torque: 30.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.36 V
    Bin. Bits: 00001100
    Temperature: 55.8*C
    (no units): 0.0
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00001000
    Temperature: 12.6*C
    Bin. Bits: 10110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00001000
    Temperature: 12.6*C
    Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
    P0673 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00001000
    Temperature: 12.6*C
    Bin. Bits: 10110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00001000
    Temperature: 12.6*C
    Bin. Bits: 10110000
    Readiness: 0 0 1 1 1
    Address 03: ABS BrakesLabels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021121
    Shop #: WSC 01279 785 00200
    VCID: 3A7D691E759309F1604-806F
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CR
    Component: Climatic PQ35 081 0404
    Shop #: WSC 00000 000 00000
    VCID: 76E5BD2E010BAD9144C-8023
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000641176
    Coding: E4890F0600041800001400001400000000
    VCID: 3F8B180A6EB12CD957A-806A
    Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 00000
    1 Fault Found:
    01064 - Terminal 58d; Interior Dimming
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600
    Revision: 05022000 Serial number: 0033JD0BWK9O
    Coding: 0012338
    Shop #: WSC 01268 785 00200
    VCID: 2D575242B4DDAE49F56-8078
    Subsystem 1 - Serial number: 6332MSME364F7D02
    Subsystem 2 - Serial number: 6342MSME08366302
    Subsystem 3 - Serial number: 6351HSME224B0002
    Subsystem 4 - Serial number: 6361HSME0B437101
    No fault code found.
    Address 16: Steeringwheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000022
    VCID: 30694B36A3EFC3A1DE0-8065
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 950 L
    Component: KOMBIINSTRUMENT VDD 3556
    Coding: 0001401
    Shop #: WSC 00581 210 64475
    VCID: 316F4E32A8E5CAA9D1E-8064
    1 Fault Found:
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Component: Tuersteuergeraet 09 0116
    Coding: 0000052
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V14
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 J
    Component: Radio BNO 0016
    Coding: 0040400
    2 Faults Found:
    00875 - Treble Speaker Front Right (R22)
    011 - Open Circuit
    00871 - Bass Speaker Front Right (R23)
    011 - Open Circuit
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C515F468FC7A741E28-8079
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    (I have deleted some of the readings because i cant post this, as it exceeds the word limit
  2. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Aug 2011
    Meath
    You need to save the codes then delete them, give it a day or 2 and rescan, I'd imagine a lot of the codes are old.
  3. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Mar 2015
    United Kingdom
    Quote Originally Posted by Doctle Odd View Post
    Hi thank you very much for the reply, i did exactly what you said and those are the codes that came up. I cleared all codes, then rescanned a day later (after taking it for a drive)
  4. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Mar 2015
    United Kingdom
    I did another scan but this time i did it differently, i took the car for a drive, then once it went into limp mode, i plugged in the diagnostic, which gave an interesting reading. (P0299 see below)
    7 Faults Found:
    P1641 - 000 -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 00001100
    Temperature: 60.3°C
    (no units): 144.0
    17911 - Load Signal from Alternator Term. DF
    P1503 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 882 /min
    Torque: 30.0 Nm
    Speed: 3.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00001111
    Load: 0.0 %
    (no units): 1.0
    16683 - Boost Pressure Regulation
    P0299 - 000 - Control Range Not Reached
    Freeze Frame:
    RPM: 3066 /min
    Torque: 248.0 Nm
    Speed: 76.0 km/h
    Load: 100.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Absolute Pres.: 2029.8 mbar
    Absolute Pres.: 1570.8 mbar
    Freeze Frame:
    RPM: 882 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Temperature: 9.9°C
    Bin. Bits: 10110000
    Freeze Frame:
    RPM: 882 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Temperature: 9.9°C
    Bin. Bits: 10110000
    Freeze Frame:
    RPM: 882 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Temperature: 9.9°C
    Bin. Bits: 10110000
    Freeze Frame:
    RPM: 882 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Temperature: 9.9°C
    Bin. Bits: 10110000
  5. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Mar 2015
    United Kingdom
    Just to update you all, i got the servo replaced (twice!) and still no luck
    Any help would be much appreciated.
    Guy that replaced the servo has booked it in again, to replace the vacuum pump again and the vacuum hose.
    I will update with the outcome.
  6. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Aug 2011
    Meath
    Seems like you need 4 glow plugs ans have the turbo/n75 checked. I'd start by checking all vacuum pipes and boost hoses. Replaced servo why?
    1 1 0
  7. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Pembrokeshire
    22 Post(s)
    ok, not read the whole thread so excuse me if i have missed something, but you are seriously beating about the bush here. the brake pedal goes hard after a few presses and it lacks power, so you have a vacuum leak somewhere, so start by replacing all the little vacuum pipes to the turbo, egr and asv and it should cure the fault for the price of 3 metres of vacuum pipe. vacuum pumps, servos, jees, someone has seen you coming and isn't very busy right now.
    but yes, you do need new glow plgs as doc says, or it could be the fuse or relay gone.
    Last edited by zollaf; 02-04-2015 at 09:09 AM. Reason: added the bit about the glow plugs.
    1 1 0
  8. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    Mar 2015
    United Kingdom
    yeah the glow plugs issue is the last of my worries, its not causing any apparent problems nor any warning lights, so ill change it in due course.
    As for the mechanics leading me on lol, no. He changed the servo twice because the initial servo he put in had an air leak. I was not charged twice for it. And the servo in this model is one heck of a job, so for him to do it twice and has said he will replace my vacuum pump and pipes for free, i think he wants to get to the bottom of it just as much as i do. The chap who fitted the initial vacuum pump was someone else. The one who is currently dealing with it is a good friend. Who is charging me peanuts.
  9. Re: MK5 Golf 1.9 TDI (BKC) Power loss/Limp mode and Esp light displays
    May 2015
    Edern
    Did you resolve the problem ? Just wondering if you did a calibration on all your newly fitted components with vag com ? Maybe that was the problem new devices installed / replaced requires vag comm to calibrate on to ecu.Otherwise your car wont see your new compnent and ecu will still be in safe mode.
  1. Audi A4 1.9 TDI (1999) - power loss...limp mode?
    By k3t4n in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2019, 05:16 PM
  2. Please Help 1.9 tdi in limp mode, power loss
    By leeg1187 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-08-2014, 01:45 PM
  3. mk5 golf r32 EPC EML ESP lights on and limp mode
    By volkswizard in forum VCDS - General Questions
    Last Post: 10-10-2013, 07:59 AM
  4. Please Help Burning Oil Smell / Loss of Low End Power / Glow Plug Light / Limp Mode
    By 5aq1b in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-05-2013, 09:54 AM
  5. Please Help 1.9 tdi power loss/ limp mode
    By geo_855 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2011, 08:43 AM
