Thread: Swival towbar not locked warning in fis
  1. Swival towbar not locked warning in fis
    Feb 2015
    Sweden
    Regards A6 2011 TDI 2.0
    I got an fault message in my FIS that the swival towbar is not locked.
    I have measured the pins to the contact who detects if the towbar is locked or not and that works.
    Any ideas?
    Regards
  2. Re: Swival towbar not locked warning in fis
    Dec 2010
    CD UK
    6 Post(s)
    Unfortunately I can't help with the electrics. Have you checked that it has physically locked in both positions correctly and also that the red light has gone green?
    Although this doesn't answer your question you will at least have confidence in its safety. I guess a VCDS scan will help diagnose any electrical faults. Good luck with it.
  3. Re: Swival towbar not locked warning in fis
    Nov 2012
    Somerset UK
    Factory fit or aftermarket?
  4. Re: Swival towbar not locked warning in fis
    Dec 2010
    CD UK
    6 Post(s)
    I assumed it's FF as it's a swivel one. Maybe you can get them aftermarket too?
  5. Re: Swival towbar not locked warning in fis
    Nov 2012
    Somerset UK
    Mine is too but it's aftermarket, Audi wanted £1100+VAT to fit and went to the place that fits them for the dealer and got mine for (inc a 4 bike rack, number plate lit board and plate) for £587 inc
  6. Re: Swival towbar not locked warning in fis
    Feb 2015
    Sweden
    Thanks for the answers guys, and I have solved the issue.
    I have retrofitted the original swivel towbar that I bought from an scrapyard. I then did my own harness whit help from Elsawin and connected to the original trailer module.
    The fault was when i mounted the knob for releasing the towbar, I didnt fitted the wire as it should be. So the sensor was always open.
    Released the wire and put the knob in proper position and connect the wire again solved the problem.
    Thanks again guys for the help.
    0 2 0
  7. Re: Swival towbar not locked warning in fis
    Nov 2012
    Somerset UK
    Gnut, no problem and glad it's sorted
    If any other probs arise with your car be sure to ask as we're a friendly bunch...just ensure if a problem you state when/how long you've experienced failure, if it was an OEM fitment/aftermarket or DIY, that way we'll be in a better postition to offer assistance and you'll get better advice.
  1. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  2. Polar FIS
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2012, 09:30 AM
  3. Polar FIS+
    Last Post: 14-05-2012, 06:12 PM
  4. FIS Display problem
    By johngibson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-08-2007, 12:13 PM
  5. FIS ??? + Vin ???
    By MPTNB in forum Passat - Archive Topics
    Last Post: 17-08-2006, 01:08 PM
