Thread: eos tdi major problems
  1. Exclamation eos tdi major problems
    Jul 2014
    norwich uk
    did a retrofit cruse controll last year car was up for mot but found we had no high beam (worked but wouldnt stay on so a fail) spoke to the very helpfull seesidevw wear i purchased parts and after they spoke to vw tec i was advised i would need to change the slider frome old unit which i did,after puting back together it was working but not as it shoud then it just stoped working re no high beam have now lost also elec windows starts and cuts out sttait away ive also got the red circle with ! in centre flashing and get 3 long errer tones when i switch on vag com wont connect to car comes up with can not ready
    any one have any thorts??
    update
    after leaving battery off overnight
    and realised what i did (me rushing as mot due) i had snapped the pin that operates the high/low beam and asume it was stuck inbetween the to
    have now fixed this part and reasembled now starts and runs windows now working ligts all working all i have now is wipers not working and
    mag-com says open circuit on switch and motor
    bust washers are working and so are the computer controlls on same switch
    cheers for any help offerd
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 521 A HW: 5K0 953 569
    Component: LENKS.MODUL 009 0122
    Revision: FF010035 Serial number: 20100219200150
    Coding: 4080140000
    Shop #: WSC 00020 999 12345
    ASAM Dataset: EV_SMLSNGVOLWS A01002
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 2B551EED42037F79EBD-807E
    2 Faults Found:
    227339 - Windshield Wiper Switch
    B1145 13 [008] - Open Circuit
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 97385 km
    Date: 2015.03.25
    Time: 02:12:48
    227355 - Windshield Wiper/Washer Switch
    B1149 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 97385 km
    Date: 2015.03.25
    Time: 02:12:48
  2. Re: eos tdi major problems
    Jul 2014
    norwich uk
    have now fixed most faults as high/low beem pin was broke got stuck inbetween and messed system up
    but still no wipers working
  3. Re: eos tdi major problems
    2005 Post(s)
    Stupid question time, is the bonnet shut?
  4. Re: eos tdi major problems
    Jul 2015
    Can't really see how the indicator stalk should affect the wipers unless something has been snagged/pulled.
    Fuse??
  1. Having a few major problems! Help
    By 4000 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2013, 12:04 AM
  2. More major problems
    By Iamtony in forum The Commercial Range
    Last Post: 25-04-2011, 12:53 AM
  3. Any major problems?
    By moore4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2010, 10:52 AM
  4. a6 major problems please help
    By heather1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-10-2009, 08:02 PM
  5. Eos water problems
    By ginger in forum Eos
    Last Post: 23-03-2007, 06:38 PM
