Thread: golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
  1. golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    Sep 2007
    My beloved Golf has lost power a couple of times recently. Almost like the turbo has stopped. Both times on the way home! The following morning it starts, and power is restored. Any ideas what it could be? It is due for its service in about 300 miles.
  2. Re: golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    Sep 2007
    Hiya
    I have the same problem with my golf and i have also had no replies!! I have found another site which gives some information about losing power if you look at the link below it may help you out
    Emma
    http://uk-mkivs.net/forums/thread/425656.aspx
    ps if you do get to the bottom of it before i do let me know thankxxxx
  3. Re: golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    Apr 2007
    N.Ireland
    This is a problem thats been mentioned many times over and its one I've even had myself. My first advice to you is to get your car connected to Vag-Com or a diagnostics machine so that the fault code can be read and you'll have a much better idea of where the problem lies.
    What is basically happening is that the car senses something is wrong and puts the engine into what we call "limp mode", which is basically like a low power, get you home while protecting the engine mode. Do a search on the forum for 'Limp Mode' and you'll find many more threads about this. The usual causes of this problem are:
    1) Faulty MAF
    2) Faulty N75 boost control valve
    3) Boost leak due to split/dislodged turbo pipe
    4) Sticking/Corroded turbo actuator arm
    5) Turbo vanes clogged with soot
    Until you get the diagnostics done, its hard to say which one of these it could be. In my case the turbo vanes were clogged and I had to get the turbo taken off and cleaned.
  4. Re: golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    Dec 2005
    I had exactly the same problem on my Golf IV. My local garage said there were no fault codes but the turbo was down on pressure. They replaced an airflow sensor that they said looked knackered but that did not help. I took it to an independent VW specialist (ex-main dealer mechanic) who diagnosed it as a build up of kack in a nozzle inside the turbo, this was causing a pressure spike under certain conditions that told the ECU to put the engine into limp mode (killing the ignition just re-sets the ECU). He removed the turbo, sent it to a turbo specialist in Leeds who stripped it, cleaned it and put it back together. It now runs perfectly and I didn't realise just how much power I had lost! As this guy was a VW specialist but still had to send the turbo away I would suggest it is not a job for the home-mechanic. It cost 500 notes but this is much cheaper than a new turbo. I guess you could try treating it with turbo-cleaner before shelling out for an overhaul (I will be doing this as a preventitive measure from now on).
  1. sharan loses power
    By moxey in forum Touran - Sharan - Caravelle
    Last Post: 22-08-2007, 01:18 PM
  2. A3 loses power!
    By manchesta19 in forum Audi A3 - Archive Topics
    Last Post: 20-04-2007, 07:40 AM
  3. 1.4 Twist Loses Power
    By keefb2001 in forum Polo - Derby - Lupo - Fox
    Last Post: 31-03-2007, 03:36 PM
  4. Golf GT TDI - Loses power but motor keep running??
    By buckworld69 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2007, 10:57 PM
  5. Golf TDI loses power at 2500rpm
    By kleky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 01:18 AM
