Thread: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
  1. Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Apr 2013
    London
    Hi I have an Audio A3 (02) the battery goes flat when we park it overnight. We also have to disconnect the red lead each time we leave the car as the alarm goes off. I need someone to look at it and/or
    a...find out whats draing the battery and fix it
    b... If above becomes a huge job then create a lead and switch so I can terminate the battery each time I stop from inside the car so I have a switch in the glove compartment or something.
    We have been disconnecting the car for a year and a half now each time we leave it (dont use it daily as we live in London and use rail) and I am worried I will brake the bonnet leaver at some point, we can do without the alarm!
    Anyone think they can help?
    Thanks in advance!
    Sam
  2. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Dec 2007
    8 Post(s)
    Look for an auto electrician to help
    In the meantime you could try to pinpoint the cause by removing fuses a few at a time to see what is draining battery.
    With everything turned off when you remove each fuse,try gently touching it back to see if arcing is occuringl,if heavy arcing is evident put that on the suspicion list.
  3. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Apr 2013
    London
    Many thanks Micheal but what is arcing?
  4. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Sam
    Take it to a garage or auto electrical shop to get problem sorted, your option B is not feasible. Continually disconnecting the battery is not good for the electronics.
  5. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Dec 2007
    8 Post(s)
    It is the electrical sparks produced when initial contact is made when touching live connection,sometimes difficult to see.
    Sam I think it is always better to disconnect the earth connection at battery first. If spanner shorts on body it is not good,and also keep in mind that dangerous gases
    are produced when battery is charging and sparks can cause explosion with these gases.It is rare but it does happen.
    Ignore these tips if you are already aware
    Regards
    Michael.
    1 1 0
  6. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Apr 2013
    London
    Thanks for your advice people I dont want to appear like an *** but I have already had this at one garage to solve and have come back £40 lighter and no joy,it seems like this is a problem that could well cost a fortune trying to detect what is going wrong and Im just trying not to get burnt on top of the money I have just spread out for another repair!
    But I will look at the fuse thing!....thanks for now!
  7. Re: Audi A3 - Battery going flat need - ELECTRIC ENGINEER -
    Apr 2013
    Glasgow
    It's not a garage you need unless they have an onsite electrician.
    Look for a dedicated auto electrician business, note not hifi installers. These guys know their stuff and may well have seen your issue, plus they have the correct equipment. You can really only do this type of test with a multimeter and loads of patience as sometimes the draw will only show up after the onboard electrics go to sleep.
  1. starting problems, flat battery Audi A6 2.7TDI
    By flyby75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-01-2014, 10:49 PM
  2. Audi 2.5 TDI heater plug light and flat battery
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:35 AM
  3. Please Help Battery going flat
    By Percy2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-02-2009, 02:46 PM
  4. help!! locked out of audi a4 with flat battery
    By snnoze in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2008, 05:14 PM
  5. Flat Battery
    By Donjon in forum Octavia
    Last Post: 29-07-2007, 12:57 AM
