Thread: 2000 1.8 A4 Smells of Egg when revved hard
  1. 2000 1.8 A4 Smells of Egg when revved hard
    Jul 2013
    York
    Hi Everyone
    I've noticed a smell of egg when my Audi is worked hard. Its fine driving normally, but when (for example) you drive it hard (overtaking etc) and then engine exceeds say 4000 rpm, you then get a smell of sulphur/ egg through the air vents.
    There's no engine management light or any change in performance
    Many Thanks
  2. Re: 2000 1.8 A4 Smells of Egg when revved hard
    Aug 2011
    Meath
    Car is overfuelling and the cat cant deal with it
  3. Re: 2000 1.8 A4 Smells of Egg when revved hard
    Jul 2013
    York
    Ok Thanks
    How do you overcome an overfuelling issue?
  4. Re: 2000 1.8 A4 Smells of Egg when revved hard
    Aug 2011
    Meath
    I'd start with a diagnostic scan, if it's been going on for a while you may need to replace the cat and/or lambdas
  5. Re: 2000 1.8 A4 Smells of Egg when revved hard
    Jul 2013
    York
    Cheers for that,
    Bloke I bought it off a couple of years ago said Cat had been changed... I'll have to look through paperwork to see if I can find proof. I did replace the front Lambda about a year ago because the engine management light started to come on and a diagnostic scan said it was that which was faulty. Did cure it at the time.
  6. Re: 2000 1.8 A4 Smells of Egg when revved hard
    Aug 2011
    Meath
    Genuine Lambda or Bosch, the cheaper ones can create problems without throwing a code. Get a VCDS scan first if you don't know anyone that has it look on this map for a member of this site near you. https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
  1. 2.oT FSI DSG moves when revved out of gear
    By uktivo in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-12-2010, 01:50 PM
  2. Changing ATF Fluid on Audi A4 1.8SE 2000. Easy or hard?
    By burkey88 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2010, 04:16 PM
  3. Chicken and egg door issue
    By dobbass in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2010, 09:23 PM
  4. rotten egg smell
    By dmk35 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2008, 06:31 PM
  5. Egg Smell
    By joeyjoejoe in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2008, 04:35 AM
