Thread: Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
  1. Question Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
    Berkshire, UK
    New Beetle Luna 1.4, 75 PS - Registered Sep 2009.
    After showing intermittent operation over many years I eventually got round to replacing the hazard warning switch / Indicator relay on the wife’s New Beetle. This is fitted just above the air vents on the centre dash assembly along with the passenger airbag off light.
    The repair was without incident and a new switch from VW (Part No: 1C0953235DB41 ) was fitted. During the replacement the switch was tested whilst the passenger airbag off light was disconnected.
    Question: Would the operation of the ignition whilst the passenger airbag off light was disconnected have caused the SRS Warning Light to have latched on?
    Of course other activities like testing the passenger airbag off switch and moving the driver’s seat during the job may also need to be considered.
    I assume it’s a trip to the dealer to get it reset but I am just trying to anticipate if I might have caused another problem.
    Any suggestions gratefully appreciated.
    Stuart
  2. Re: Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
    May 2007
    17 Post(s)
    Quote Originally Posted by Stuart_Tayler View Post
    YES
    Not necessarily. Have you check to see if there is a forum member in your area that has diag equipment and might be willing to reset it for you? Take a look here :
    https://www.google.com/maps/d/viewer...a=0&dg=feature
    Regards.
    Jim.
  3. Re: Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
    Berkshire, UK
    Spot on - I loved your concise response.
    Thank you
  4. Re: Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
    Southern County Softy
    20 Post(s)
    A scan would be the first thing to do, then clear the faults and see what comes back.
    There is a map that's shows members with VCDS willing to help.
    A4 2.5 tdi QS (mapped)
  5. Re: Airbag Warning Light (Supplemental Restraint System (SRS) Warning Light) stays on after replacing hazard warning switch.
    20 Post(s)
    Glad to of been of service.
  1. Please Help Hazard Warning Light Switch Repair/Removal
    By Antoshkin in forum Golf MK4 - 1999 - 2004
    Last Post: 10-02-2012, 12:59 PM
  2. Airbag Warning Light - Stays On
    By ajdletmein in forum Polo - Derby - Lupo - Fox
    Last Post: 25-11-2009, 09:19 PM
  3. Hazard Warning Light Switch
    By jsbarcs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-12-2008, 02:15 PM
  4. hazard warning light switch
    By tricolourdog in forum Bora - 1998 - 2005
    Last Post: 25-01-2008, 06:28 AM
  5. Replies: 0
    Last Post: 04-12-2007, 03:22 PM
