Thread: TDI won't start at warm engine
  1. Exclamation TDI won't start at warm engine
    Jun 2014
    Monterrey, Mexico
    Hi guys
    I am having a strange issue over here, but may be easy for any of you. I changed fuel injectors to my Audi Q5 3.0 TDI and high pressure pump. Everything seemed ok, but....
    Cold engine:
    I press start button, it cranks up for about 1 second and engine fires up. It always fires up on cold engine. I turn off engine and on again without problems.
    After driving for some time until engine heats up, I turn it off. Then I press start button and engine wont start! It may start but sometimes I need to crank for about 30 seconds. It only happens when engine is warm. After I wait until engine cools down, it fires up with no problem.
    I really have no clue and haven't found any answer over here. I thought I needed to drive constantly and problem would dissappear but it didn't.
    ** While driving, glow plugs start blinking for no reason.
    I appreciate any help. Thank you very much!!
    Javier
  2. Re: TDI won't start at warm engine
    Jun 2014
    Monterrey, Mexico
    Here I share an image with actual values while cranking (warm engine). Does anybody see something odd here?
    I am thinking this is fuel pressure related, but my question is... why is the engine working everything OK, but when I turn off then it wont turn on again?
    This image show values when cranking and no luck.
    These are values taken before turning engine off.
  3. Re: TDI won't start at warm engine
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Should hot cranking speed be above 280rpm to start ?
    Maybe others could confirm.....
  4. Re: TDI won't start at warm engine
    Jun 2014
    Monterrey, Mexico
    Hi friend. Even at higher rpm it won't start.
    I've found, after a lot of tests, that my maintenance valve (the tiny barrel at the injector return lines) is from a 2013 model, and is different in size than a 2011 model. I did a trick to my engine. I squeezed a little the return line after the maintenance valve with a wrench, and it caused the engine to start, even at a warm temperature. Without the wrench it is not possible for the engine to start. After it starts, and without the wrench, engine stays on and with no problems at all.
    I think the pressure at the return lines is not enough because of that valve. I must find the right one.
    Wish me luck!
    Javier
    Here is a picture of a 2011 vs a 2013 model.
    2011
    2013
  1. AFN TDI engine won't start
    By shabazmo in forum Golf MK4 - 1999 - 2004
    Last Post: 22-02-2013, 11:49 PM
  2. 2000, Y, A6 2.5 TDi AKE. Engine won't start & VCDS won't connect to 01
    By jtonthebike in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-09-2012, 03:35 AM
  3. GT TDI130 Won't start when warm
    By stutdi130 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2008, 02:57 PM
  4. A4 TDI oil light on and engine won't start??
    By porchie in forum Archive posts
    Last Post: 22-11-2007, 11:07 PM
  5. A3 won't start when Engine Warm
    By Oldalfie in forum Audi A3 - Archive Topics
    Last Post: 11-11-2007, 01:58 AM
