Thread: Replacing reversing light on 2012 Audi A6 Avant estate
  1. Replacing reversing light on 2012 Audi A6 Avant estate
    Mar 2015
    Aylesbury, UK
    Can anyone help? I can find countless videos and guides on how to replace bulbs for A4s and early A6 saloons but nothing for a 2012 Audi A6 Avant estate.
    Please can you give me any advice on how to remove the cluster from the inside? It looks impossible!
  2. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    46 Post(s)
    Surely it should be in your owners manual?
  3. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    I got told off for saying that.
    0 2 0
  4. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    I believe the reversing bulb is on the tailgate light cluster; so open tailgate- obviously; slide the small cover outwards and it will slide out. Look up and you will see a 10mm nut on a plastic bracket, undo this nut and the bracket will fall away from the cluster, unplug connector and lift cluster away from outside. It may need to be shifted outwards as it has a small lip along the tailgate edge.
  5. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    Mar 2015
    Aylesbury, UK
    Hello and thanks for the advice but the light cluster on an estate is on the rear corner of the body, not the tailgate.
    If you look inside the boot where the cluster is attached to the body there are no bolts or screw heads visible. Just two or three plastic clip type things (all different) that are immovable by hand and feel as though they would break if I tried to turn them or move them with pliers.
    In videos for A4 estate there's an easy removal process. Not so for the A6!!!
  6. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Are you sure?? Have you physically looked at the back of the avant with the reverse lights on? No i doubt it! maybe you should do and maybe just maybe RTFM !! Audi have supplied you with one for exactly that reason and not for lazy owners who can not be bothered to pick it up but instead make posts asking for help !!
  7. Re: Replacing reversing light on 2012 Audi A6 Avant estate
    Aug 2013
    18 Post(s)
    Have a look at pages 270 to 272 of your manual
  1. A6 Avant Reversing Light - How to change?
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2016, 01:18 AM
  2. Solved Replacing a dodgy reversing sensor on my A6 Avant
    By Stevewoodmeuk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-06-2014, 09:39 PM
  3. Important 2008- AUDI A4 S4 B8 AVANT FACELIFT 2012- REAR LED LIGHT advice sought
    By andylef in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2014, 05:21 PM
  4. Audi A4 Avant 2002 Reversing sensor prob.
    By Jaunt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2009, 08:00 PM
  5. Replacing reversing light switch - Passat.
    By jakefouro in forum Archive posts
    Last Post: 03-02-2007, 01:58 PM
