Thread: Weird noise from engine (TDi PD130 2003)
  1. Weird noise from engine (TDi PD130 2003)
    Oct 2006
    My car is a November 2003 Passat tdi pd130s. It has covered 37k approx and has been making a noise that clearly should not be happening. When the car has been in the office car park all day, particularly on a hot day, a few minutes after starting it will make a hissing / shrieking niose. The first time it happened was on a very hot day this summer and the noise was so loud that I nearly crashed the car. It sounded like a very high pressure hiss and only lasted a second on so. The dealer has replaced the radiator, and checked the turbo and all the belts and can not find any fault. The car's driving is completely anaffected but I am worried that there will be a breakdown, almost certainly after my warranty expires next month! The niose does occur fairly often, is only ever for a second or so, but it's not as loud as it used to be, and now sounds more like a quick shriek than a hiss. Does any one have any ideas?
    Oct 2006
    Try starting your car with the climate control turned off a few times if the fault is not there then suggest air con compressor starting to seize up causing drive belt squeel especially if its worse on a hot day the compressor has to work harder hope thats of some help
  1. Knocking noise in engine
    By marathon in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-05-2007, 06:16 PM
  2. 2002 A4 SE Avant Weird knocking noise at rear
    By Tanuki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-03-2007, 11:53 PM
  3. throttle body noise golf gti 2003 (180)
    By minky in forum Archive posts
    Last Post: 05-01-2007, 07:43 AM
  4. engine bay grating noise
    By COLIN in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2006, 01:07 PM
  5. Mk 2 Golf Engine noise
    By Dave Gibson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-10-2005, 11:01 AM
