Thread: Mk5 engine judder when idle
  1. Mk5 engine judder when idle
    Oct 2009
    huddersfield
    Hope some may be able to help. My Mk5 golf TDI is starting to judder and shake when idle or at a stand still. Problem is gradually getting worse. Any solutions or ideas much appreciated. Having it hooked up to a VAG COM on Monday to check for codes.
  2. Re: Mk5 engine judder when idle
    doctleodd Guest
    Any problems getting into gear or changing gears? Any change in the feel of the clutch?
  3. Re: Mk5 engine judder when idle
    Feb 2015
    London
    Sounds like it could be the bearing in the dual mass flywheel failing. Had the same issue on my old E60 BMW
    My Daily: A6 C7 2.0 TDI SE, Phantom Black, Privacy Glass, Advanced Key, Colour DIS, DAB, 4 Zone Climate, Heated Seats, 4 Way Lumbar, Pre-sense Basic, Parking System Plus, Folding/heated Mirrors, Bi-Xenons, Rear Side Airbags, AMI, Lighting Pack, Storage Pack.
    My Baby: 1995 Corrado 2.9 VR6 Storm, Mystic Blue Heated Leather
    Performance figures measured by Stealth: 207.7 BHP | 197.3 lbs/ft |
  4. Re: Mk5 engine judder when idle
    134 Post(s)
    2005 Post(s)
    The DMF can be a source of idle shacking on the BKD engine but it can also be the cam timing being very slightly out. We have seen a number of cars come in with (un-reported) idle shake which has faded or gone when a cam belt has been changed with **** attention to the cam timing. The crank setting is easy to get right but the cams cam be a real pain to get absolutely spot on to the point you can get a pair of VW cam pins in without issue.
  5. Re: Mk5 engine judder when idle
    Oct 2009
    huddersfield
    Thanks for replying. No issues with gear shift or changing gear. I had DMF and clutch replaced last year. Pretty certain this is something in the engine bay. Car chugs and judders as if it's about to cut out. Revs remain consistent. Was advices it may be an injector. I've been using shell Vpower diesel and the problems has got slightly worse since.
  6. Re: Mk5 engine judder when idle
    134 Post(s)
    2005 Post(s)
    Open up the fuel filter and have a look at the colour of the fuel in there.
  1. Trouble starting from cold and judder at idle on 1.9 PD engine
    By iaindhill in forum Golf MK5 - 2004 - 2009
    Last Post: 27-10-2014, 05:52 PM
  2. 2.0 tdi bmn / bkd engine idle misfire/judder PLEASE HELP!!!
    By GTRUSS in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2012, 04:34 PM
  3. Question Poor fuel consumption,engine judder at idle and turbo cutting out at speed!
    By chrisw85 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-01-2012, 01:46 PM
  4. Mk5 GT TDI 140 engine shudder at idle
    By pricey01 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-03-2011, 03:23 PM
  5. Please Help gti tdi 150bhp idle judder and low throttle judder
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2010, 10:42 AM
