Thread: Oil temp gauge issue's
  1. Oil temp gauge issue's
    Jan 2015
    Eastbourne
    I've just changed the Oil level/temp sensor in the sump to try and get the gauge working again, it does not go up while driving along but if I turn the ignition back on after i've parked up it does this:
    As you can see it reads a temp but as soon as the car is started it drops. does anyone have any idea's why it works then doesn't?
    Audi A4 1.8t B5 - W Reg - Now with lambda fault (Bosch part on route from finland!)
    Completed:
    Temp Sensor, Thermostat, Coolant change, Fixed indicator fault, new number plates, LED Number plate lighting, Oil temp sensor, Full filters change + oil + sparks, drain bung blockage removed
    To do ASAP: Drivers side CV Boot, passenger speaker, EVAP Solenoid valve (Part on route)
  2. Re: Oil temp gauge issue's
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Maybe a Cluster fault. Can you check the connections at sensor with ignition ON and then again once running? You may find an issue with feeds or earths?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Oil temp gauge issue's
    Jan 2015
    Eastbourne
    Thanks for that Alan think you might be right with an earth, might try re grounding the oil temp sender and see what happens
    Completed:
  4. Re: Oil temp gauge issue's
    Nov 2008
    20 Post(s)
    Hi, if this helps: Oil temp BL/W @sensor to 4a/1 on cluster.
    Oil pressure W/B @sensor to 26a/18 on cluster.
    Earth looks to be thru body of sensor.
    BL/W = blue wire, white tracer.
    W/B = white wire, black tracer.
    Alan.
  5. Re: Oil temp gauge issue's
    Jan 2015
    Eastbourne
    Thanks for the info Alan
    I thought the sensor was a integrated level/temp sensor with 3 pins not oil pressure thought that was driven off a sensor in the oil cooler?, I found this info on another Audi site while looking last night (won't put link as don't know if its against rules!)
    Pin1 - 12V Switching
    Pin2 - Ground
    Pin3 - Signal Continuity to ecu\cluster
    But going back to that site to get the info I followed link in the thread and it seems lots of people having this problem even after replacing still it if they never bought a hella branded one they seem to be the only ones that work correctly ( and I don't have a hella branded one )!
    Completed:
  1. Advice required by newbie MK4 owner - Blowers/Temp gauge issue...
    By SamwelGTTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2010, 07:15 PM
  2. No oil temp on gauge
    By catweazle in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-01-2009, 08:57 PM
  3. A4 Water Temp / Oil Temp gauge
    By Zulu in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2008, 06:24 PM
  4. Oil Temp Gauge
    By rob1380 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 09:01 PM
  5. a4 2.8 oil temp gauge
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2007, 01:42 PM
