Hi all.
The vehicle is difficult to start without applying the accelerator. Once running, the idle is very poor. Plugs and coil packs ok. Old codes cleared and the only one which returns is P1340 engine speed/ cam sensor correlation.
Other than idle, the car goes well.
On checking the chain timing all seems well except that the inlet cam (nearest the front) was in the fully advanced position.
N205 valve clicks and you can see the inners of the valve moving back and forth. Like wise with the other valve.
The variable cam vane moves back and forth when a spanner is applied to the hex on the cam.
If anyone has a label file for this vehicle would help.
Any thoughts?
