Thread: Audi A3, 2L TDI 16v BKD engine start problem
  1. Question Audi A3, 2L TDI 16v BKD engine start problem
    Feb 2015
    Siauliai, Lithuania
    Hi, everyone,
    I'm facing problem with cold engine start, when cranking it feels like like not all not enough or too much fuel and and cylinders misfire or smth...
    Turning off and then starting again is way better.
    The problem appears after a car stood still for over the night or couple of hours. Sometimes it starts without a problem 1/2 crank hot/cold...
    Here's a video:
    Dropbox - VID_20150224_074954.mp4
    Injectors at idle stabilization:
    Glow plugs are new, oil and filters(fuel, oil) changed 5000km ago.
    No fault codes
    Fuel temp, engine temp sensors show correct temperatures. Crankshaft and camshaft are good.
    Torsion value 0.0/0.5 .
    So what can cause such a problem? Tandem pump? Air leakage? Leaking injectors?
  2. Re: Audi A3, 2L TDI 16v BKD engine start problem
    Nov 2014
    sr mitorvica vojvodina
    If smel disel may be gasket on tandem pump may be senzor
    of flow air protocomer translate this word
  3. Re: Audi A3, 2L TDI 16v BKD engine start problem
    Feb 2015
    Siauliai, Lithuania
    All temp sensors show correct temperatures... No noticeable diesel smell when starting the engine.
  4. Re: Audi A3, 2L TDI 16v BKD engine start problem
    131 Post(s)
    1978 Post(s)
    When you changed the fuel filter, what colour was the fuel?
  5. Re: Audi A3, 2L TDI 16v BKD engine start problem
    Feb 2015
    Siauliai, Lithuania
    Quite dark, but I read that it's normal for PD engine. Filter was changed about 8000km ago. Maybe it's related to ecu engine start map?.. Friend has audi a4 '07 with 16v pd BRE and 180k km on clock - no starting problems...
  6. Re: Audi A3, 2L TDI 16v BKD engine start problem
    131 Post(s)
    1978 Post(s)
    When the fuel in the fuel filter is black it means the tandem pump is leaking engine oil into the fuel and the fuel in the tank will be heavily contaminated with dirty engine oil. The fuel in the filter pot should be as for clean diesel with just some light debris in the bottom. This problem is a common cause of poor idling on the BKD engine.
    1 1 0
  7. Re: Audi A3, 2L TDI 16v BKD engine start problem
    Feb 2015
    Siauliai, Lithuania
    It's tandems' pump gasket or itself?
    But the idling is OK, only random start when engine cold/warm ...
  1. 2.0 ltr BKD diesel engine Timing locking pin problem
    By oldandbald in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-04-2014, 08:02 PM
  2. Golf TDI GT SPORT BKD won't start when stood for over a day?
    By Sly in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2012, 09:59 PM
  3. Question What is the black ball **** type thing in 2.0l BKD engine in Gt tdi engine bay?
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 24-05-2010, 06:04 PM
  4. Removing Engine Cover on 2.0L gt tdi BKD
    Last Post: 10-03-2010, 09:07 PM
  5. car won't start again 16v kr engine
    By gwh18 in forum Golf MK2 - 1984 - 1992
    Last Post: 10-07-2009, 03:51 PM
