Thread: 1.6 FSI - grumbling noise on load
Results 1 to 8 of 8
  1. 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    HI
    Help please. I have a 2003 1.6 FSI Touran that's covered 75k. Recently I've found it appears to make a deep grumbling noise when accelerating under load. It seems to get quieter once the car has reached temperature. I've replaced the flexi pipe that comes from the down pipe at the front of the exhaust as that had a hole in it. But the noise is still there. It does seem to have got worse the past week and seems to be louder when the weather is cold. The rest of the exhaust seems new and doesn't blow. The car pulls fine in all gears. When the car is on tick over the engine is fine and has no noise.
    Any ideas
  2. Re: 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    I have starting to think this was exhaust related again. I've been all through the exhaust and can see no holes and everything seems sounds enough with no rattles of baffles being damaged etc. But I still have the groaning noise. It comes in on about 20% load when accellerating.
    I got the following fault codes this morning also when I ran a check - 19490, 05410, 18068
    any ideas, anyone????
  3. Re: 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    I took the car to the local kwik fit yesterday to get the exhaust system tested. They confirmed what I thought in that nothing is wrong with the exhaust system.
    So the noise is this present. I've booked the car into a local garage later this week for another opinion.
  4. Re: 1.6 FSI - grumbling noise on load
    Aug 2011
    Meath
    What did you use to read the codes?
  5. Re: 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    Hi - code reader from ebay
  6. Re: 1.6 FSI - grumbling noise on load
    Aug 2011
    Meath
    Quote Originally Posted by Jedkk View Post
    A scan with VCDS or VAS-PC would be helpful, lots of members of this site have VCDS and will scan your car.
    https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
  7. Re: 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    cheers
  8. Re: 1.6 FSI - grumbling noise on load
    Jun 2012
    Blackburn
    The car went to a local garage today and it is now running nice and quiet again. It was the exhaust the garage that had fit the flexi pipe for me had left the exhaust touch the body work so it vibrated under load. They took it off and refit the exhaust and now I have a quiet car again. Strange how the national high street exhaust place didn't spot that.
  1. Please Help S3 Screeching noise under load
    By acmo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-01-2015, 09:11 PM
  2. Golf Mk5 2.0 FSI - Fluctuating/High Engine Load when car is just idling
    By garymansell in forum VCDS - General Questions
    Last Post: 13-09-2014, 01:02 AM
  3. Golf Mk5 2.0 FSI - Fluctuating/High Engine Load when car is just idling
    By garymansell in forum Golf MK5 - 2004 - 2009
    Last Post: 11-08-2014, 02:28 PM
  4. Question Audi A3 1.9 Tdi AUTO - grumbling noise from steering at idle
    By karl_tanner in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-03-2013, 10:37 PM
  5. Grumbling noise at idle A6 1.9tdi
    By morticiaskeeper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-12-2007, 08:13 PM
