Thread: Boost problems after ECU update at AUDI
Results 1 to 10 of 10
  1. Boost problems after ECU update at AUDI
    Mar 2014
    Stourbridge
    Please help!!
    I have an AUdi A3 Quattro 2.0 TDI (BKD) which I brought early last year with an over boost problem and after nercing the boost issue for over 15,000 miles I thought it was about time that I changed the Turbo. However as I was unsure if the car had been remapped and I didn't want to kill the new Turbo I thought it would be a good idea to go along to AUdi and get the ECU updated. So off I go to Audi and the update was done without any issues....
    Well i soon noticed that in first and second gear the car had no boost which I put down to the faulty Turbo.
    I have now changed the Turbo and the issue is still there.
    what I have done so far....
    1, I have fitted a vacuume gauge to the actuator vacuume pipe and I can see that there is no drop in vacuume in first and second gear and the vacuume stays at around -20 PSI unlike when in the rest of the gears there I get a change between -20 and -3/5 depending on how I accelerate
    2, I have checked all the pipe work for leaks and all looks and sounds OK
    3, I have replaced the throttle body as this failed due to age
    4, I have changed the Vacuume solenoid
    5, I have checked the fault codes which are totally clear
    when in the other gears the car flies and pulls like a train with boost coming in around 2,200 revs.
    my thoughts on this are that the car had been remapped before I brought it and this issue is due to this
    has any one got any ideas that might help or even if it is possible to get an original MAP put back on to the ECU if this is what is causing my problems with first and second gear
    Hope this is clear enough
    thank you in advance
    John
  2. Re: Boost problems after ECU update at AUDI
    Aug 2011
    Meath
    Boost should be coming on instantly or as near as dammit. What exactly did Audi do with the ECU? Did Audi replace the turbo and why was it replaced?
  3. Re: Boost problems after ECU update at AUDI
    Mar 2014
    Stourbridge
    Hi thank you for your reply
    the boost does come in right away in 3,4,5,6 but there is a positive surge in power around 2,200 rpm
    the Turbo was replaced due to the old unit having sticky vanes so I thought I would change the compleat turbo which I did myself as I have changed may in the past without any issues
    hope this helps
  4. Re: Boost problems after ECU update at AUDI
    Aug 2011
    Meath
    There's something not right, perhaps one of the vacuum pipes is collapsing inwards or has a small split but you should have boost as soon as you drop your clog
  5. Re: Boost problems after ECU update at AUDI
    Mar 2014
    Stourbridge
    I have checked the pipes and the only thing that might give the same result as a collapsed pipe might be the vacume pipe that goes to the actuator where I cut it when I teed it to fit the vacume gauge IT now has an in line connector to join the 2 ends where the T piece was
    I will order some cilicone vacume pipes at the and get them replaced just in case
    thank you
    1 1 0
  6. Re: Boost problems after ECU update at AUDI
    Pembrokeshire
    22 Post(s)
    where did you buy the new turbo from.
  7. Re: Boost problems after ECU update at AUDI
    Aug 2011
    Meath
    Hopefully not from Mr Wong!
  8. Re: Boost problems after ECU update at AUDI
    Mar 2014
    Stourbridge
    lol I spend money at audi getting an ECU update so nothing goes wrong with the new Turbo do you really think Mr wing Wong sold me a turbo lol I got it from euro car parts at £680
    im sure the new turbo is ok as it did the same on the old turbo but only after the ECU update
  9. Re: Boost problems after ECU update at AUDI
    May 2015
    Essex
    john I got same problem matey , I was experimenting the other day and took the vacuum resivour pipe off it cured it for a while the car drive brilliant
    John[/QUOTE]
  10. Re: Boost problems after ECU update at AUDI
    May 2015
    Essex
    Ive been told it's more than likely the actuator rod length or actuator screw needs adjusting , but if I do tht then warranty for my turbos void ,,, have u solved issues ????
    John[/QUOTE]
  1. Audi 2G MMI Update problems
    By Sanjib Dhar in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 20-08-2014, 02:17 PM
  2. audi 1.9tdi b6 boost problems??
    By n1ck-1 in forum VCDS - General Questions
    Last Post: 16-01-2013, 12:19 AM
  3. 3.0TDI ECU update
    By SunnyBard in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-03-2012, 08:22 PM
  4. ECU software update
    By Chris-h in forum Golf MK6 - 2009 - 2013
    Last Post: 21-06-2011, 01:24 PM
  5. ecu update
    By jamedvickni in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2008, 09:15 PM
