looking to replace my steering wheel but all the ones I seem to find on ebay have a different connection point where the airbag clamps onto the steering wheel. if I got new steering wheel with airbag to match, would my existing wiring be the same as both being same design and both non multifunction. or can the cage which holds the airbag be replaced so I could just replace steering wheel and cage and use my existing airbag. thanks
Wednesday,14,January,2015,18:10:01:45257
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVGZZZ1TZ8W091167 License Plate:
Mileage: 110140km-68437mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 52 56 62 72
76
VIN: WVGZZZ1TZ8W091167 Mileage: 110140km-68437miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 MP HW: 03G 906 021 AN
Component: R4 2,0L EDC G000AG 1322
Revision: --H07--- Serial number: VWX7Z0G93NP1UQ
Coding: 0000078
Shop #: WSC 01324 785 00200
VCID: 79FF9DC830699BE9285-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 050 E HW: 02E 927 770 AE
Component: GSG DSG 081 1402
Revision: 04608010 Serial number: 00000709260539
Coding: 0000020
VCID: 1421CC7C37CB4681DB3-8041
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023238
VCID: 73E3AFE01205E1B9629-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CF HW: 1K0 907 044 CF
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
Shop #: WSC 131071 1023 2097151
VCID: 6DD7B99874213749B4D-8038
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007802395
Coding: 01890F2100040F0047120C000000000000087F075C00010000 0000000000
VCID: 71EFA5E86819D3A9905-8024
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 181007 021 0501
Coding: 00038805
Shop #: WSC 01324
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 HW: 1K0 919 475
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 193
Coding: 100101
VCID: 6FEBA390BE2DC559861-803A
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D06PZ5L
Coding: 0012340
VCID: 366556F441F7B491857-8063
Subsystem 1 - Serial number: 6332QSME43391A016
Subsystem 2 - Serial number: 6342QSME4334353FG
Subsystem 3 - Serial number: 6352QSME3F66497D/
Subsystem 4 - Serial number: 6362QSME3F77134DV
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 636 0070
Coding: 0010042
VCID: 0009F02C53B3CA216FB-8055
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 974 A HW: 1T0 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G93NP1UQ
Coding: 0003401
Shop #: WSC 00445 210 105457
VCID: 356751F85CF1BF898CD-8060
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 261007F2001386
Coding: EDA07F0E400A028003
Shop #: WSC 00445 210 105436
VCID: 306960ECA3939AA1DFB-8065
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 110145 km
Time Indication: 0
Date: 2000.00.00
Time: 18:03:47
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Shop #: WSC 00000 000 00000
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H11 2660
Revision: AB001001 Serial number: VWZ6Z7I1376111
Coding: 000104000400008300
VCID: 2E557E9479A78C51CD7-807B
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 237
Mileage: 110145 km
Time Indication: 0
Date: 2000.00.00
Time: 18:02:38
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1202
Coding: 0000693
VCID: 387958CC4BE342E197B-806D
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.071 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 9890020851030C7F2D06840570085FC690FC00
VCID: 0303FF2042A5D139729-8056
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000692
VCID: 397F5DC870E95BE9685-806C
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 237
Mileage: 110145 km
Time Indication: 0
Date: 2000.00.00
Time: 18:02:38
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 377B5BF046FD4D999E1-8062
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End-------------------------(Elapsed Time: 02:03)--------------------------
