Thread: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
Results 1 to 10 of 51
  1. Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    Jan 2009
    I recently changed the water thermostat on our B6 1.9TDi to cure low temperature problem. This seemed to cure the problem but noticed the coolant level had dropped from Max to just below Min in the space of a week. Topped up the system yesterday, and tightened up the two bolts on the flange of the plastic housing which attaches to the engine. The thinking being that the thermostat seal wasn't quite water-tight. This seems to have cured the leak however this morning a short run of 8 miles the temp gauge is stuck on 50 and as I arrived back home the engine management light came on and the fan was going. So it's like the thermostat isn't even operating (closing) at all now. I can't see how nipping up the mounting bolts has caused this. Obviously a massive concern, any ideas?
  2. Re: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    Aug 2011
    Meath
    Low reading might meant the CTS is goosed
  3. Re: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    Pembrokeshire
    22 Post(s)
    turn the heater onto full blast full heat. it should get scorchy hot. does it, or do you get just warmish air.
  4. Re: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    glasgow
    35 Post(s)
    it could well be the new thermostat is faulty
    as suggested, let engine tick over for 10 minutes and put heating to the hottest it can go, air con off & put the heater fan on full blast for 10 minutes. this gets rids of any air locks in system.
    Also feel top radiator hose to ensure hot water is going into the radiator !
  5. Re: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    Jan 2009
    Thanks, I will check that as soon as I can. The thermostat was working perfectly until yesterday when I tightened the bolts slightly, and the temp reading was 85 degrees which I believe is normal. Seems a coincidence. Also the sensor was replaced in the last year too (but was probably unnecessary).
  6. Re: Please help, Changed Water Thermostat now getting Engine Management Warning and Fan On
    Jan 2009
    Hi chaps, just braved the miserable weather outside. I ran the engine for about 10 mins, heater on full and warm air was blowing through - not what I would call hot but maybe needed to run longer as was starting from cold. However I did feel the hoses - radiator top hose felt warm, hose to bottom of coolant reservoir was warm and I could feel warmth in the rubber hose which connects up towards the thermostat housing. Warm but not hot but then should they be hot within 10 mins?
    The Engine Management light is still on. What do you think?
    Also, is there a socket where I can plug an ODB2 code reader in?
  1. Engine management warning.
    By blodnob in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-07-2012, 10:35 PM
  2. Replies: 13
    Last Post: 11-04-2012, 07:27 PM
  3. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  4. Coolant Fan - Engine Management
    By steveieboy205 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 09:43 AM
  5. A4 Engine Management Warning Light
    By ukdeluded in forum Audi A4 - Archive Topics
    Last Post: 04-12-2007, 08:18 PM
