Thread: Where I should order brake pads and wheel nuts ?
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 53
  1. Re: Where I should order brake pads and wheel nuts ?
    #31
    Aug 2011
    Meath
    As advised earlier eBay probably not the best way to go. I believe some sellers may be selling rebadged Asian made junk, you really only find out when they go wrong. Is there no motor factor that you can walk into? If not at least Eurocarparts or GSF have some comeback.
  2. Re: Where I should order brake pads and wheel nuts ?
    #32
    Jul 2014
    Glasgow
    I bought it from ebay, all works fine I think, I got better brakes definitely.
    When I was doing bleeding for brakes, I did open vent for each side (separately) and press the brake pedal down, once I see brake fluid going out I closed vent. Was it correct way of bleeding ?
  3. Re: Where I should order brake pads and wheel nuts ?
    #33
    Feb 2013
    Gloucester
    57 Post(s)
    Ebay? For brakes? As in the things that stop your car? EBAY? Really?
    Good luck
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
    0 2 0
  4. Re: Where I should order brake pads and wheel nuts ?
    #34
    Pembrokeshire
    22 Post(s)
    ebay is fine as long as you buy from a reputable company selling known brands. if you just find the cheapest non branded stuff that claims to be made by brembo for a quid, then good luck to you.
    0 3 0
  5. Re: Where I should order brake pads and wheel nuts ?
    #35
    Jul 2014
    Glasgow
    I bought Mintex discs and brake pads. It was exactly the same as in eurocarparts or any other store, but 10-15 GBP cheapers.
  6. Re: Where I should order brake pads and wheel nuts ?
    #36
    Aug 2011
    Meath
    That's not the best way to bleed the brakes, you need either vacuum, easibleed style or an assistant
  7. Re: Where I should order brake pads and wheel nuts ?
    #37
    Jul 2014
    Glasgow
    Okay, can you tell me how to bleed if I have an assistant ?
  8. Re: Where I should order brake pads and wheel nuts ?
    #38
    Jan 2006
    Near Basingstoke
    remove cap on resevoir, connect a clear hose to the caliper bleed nipple and into a jar. Assistant pushes brake pedal while you open bleed nipple with spanner. hold brake pedal down while closing nipple...raise brake pedal and repeat until no more air bubbles are seen in clear tube. Check resevoir level regularly or you'll be bleeding the whole system!
    https://www.youtube.com/watch?v=lPwM2vn3bT0
  9. Re: Where I should order brake pads and wheel nuts ?
    #39
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Edzha- for peace of mind I suggest you get a garage to bleed/ change your brake fluid and check the brakes over while doing it. Keep the invoice that shows this has been done and show it to prospective buyers to prove that the brakes have been inspected at a garage, it should help you sell the car later in the summer. Some buyers are wary of jobs done at home, especially brakes!
  10. Re: Where I should order brake pads and wheel nuts ?
    #40
    Aug 2011
    Meath
    Quote Originally Posted by Rob69 View Post
    ^^Might be a plan^^ A garage or dealer will change the brake fluid for small money (this should be done every 2 years whether you're selling of keeping the car)
    To bleed the brakes with an assistant you start with the wheel furtherest from the reservoir. Fill the reservoir with fluid and attach a small snug fitting pipe to the bleed nipple. Put an inch of brake fluid into a disposable container and put the other end of the pipe into the container so as the end of the pipe is submerged in the brake fluid. Have the assistant pump the pedal until it's firm them hold the pedal down. Open the bleed nipple and fluid/air should be seen in the pipe coming from the nipple. When the pedal hits the floor close the bleed nipple and release the pedal. Repeat until fluid without air bubbles come out of the nipple then move on to the next wheel.
    http://www.halfords.com/motoring/gar...h-bleeding-kit
  1. Jamie's Vectra C brake pads / discs and wheel bearing
    By JimC64 in forum Chat - Anything with wheels
    Last Post: 28-04-2014, 12:58 AM
  2. Locking Wheel Nuts
    By sk8853 in forum Chat - Anything with wheels
    Last Post: 06-03-2012, 11:53 AM
  3. Replies: 1
    Last Post: 31-12-2010, 08:47 AM
  4. wheel nuts?
    By vwcool in forum Golf MK2 - 1984 - 1992
    Last Post: 08-01-2010, 07:29 PM
  5. wheel nuts??
    By sgtpile in forum Golf MK3 - 1993 - 1999
    Last Post: 01-12-2007, 05:41 PM
