Thread: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
Results 1 to 10 of 18
  1. Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Oct 2014
    Romania, Vrancea
    Hey
    I was driving one evening and just before parking my car freaked out everything went dark for aprox 30-60 sec and i wrote ABS FAIL and i didn't wanted to drive the gear information was marked with wchte and it was like the car was in N ,I could not make go forward or backwards i restarted the car and everything was normal.... then today again slow speed and board went in black.... I took a read in VCDS and it write over voltage +17 V it seems to be the error but im not sure... The car have recently changed Generator + Air pump + Growplugs 5 of them.
    here is the read out i did not got readout from gear box but it is same over voltage 17 V
    Really hope someone can help here
    Code:
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 4F0 910 402 A    HW: 4F0 907 401 C
       Component: 3.0L V6TDI  G000AG  0030
       Revision: --H04---    Serial number:
       Coding: 0011372
       Shop #: WSC 00011 888 81093
       VCID: 1B3531E7DA501BC6611-804E
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:19
                 Freeze Frame:
                        RPM: 819 /min
                        Torque: 117.0 Nm
                        Speed: 3.4 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 17.63 V
                        Bin. Bits: 00101000
                        Torque: 218.4 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans
    Cannot be reached
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
       Component: ESP 8.0 quattro H05 0040
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0000392
       Shop #: WSC 02325 785 00200
       VCID: 64C74A1BA7AE643E10B-8031
    1 Fault Found:
    00532 - Supply Voltage B+
                001 - Upper Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:17
                 Freeze Frame:
                        Hex Value: 0x0900
                        Hex Value: 0x4006
                        Hex Value: 0x0003
                        Hex Value: 0x22DA
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100715748
       Coding: 0000131
       Shop #: WSC 02323 785 00200
       VCID: E3C5C90722A0E306691-80B6
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    1 Fault Found:
    00447 - Function Limitation due to Over-Voltage
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:20
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 732 S    HW: 4E0 035 729
       Component: Interfacebox    H43 5150
       Revision: 00000000    Serial number: 350C.077769648
       Coding: 0013002
       Shop #: WSC 00000 000 08192
       VCID: 3365F94752C0B386591-8066
       Subsystem 1 - Part No: 4F0 910 609
       Component: Bedienteil MMIC6H07 0870
       Subsystem 2 - Serial number: 00000000039997
       Subsystem 3 - Serial number: 0106.08.040000000100010220’
       Subsystem 4 - Serial number: 010220’
    No fault code found.
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000030221761
       Coding: 0002326
       VCID: 1C3732FBDF5E1CFE68B-8049
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
                003 - Mechanical Failure
                 Freeze Frame:
                        Fault Status: 01100011
                        Fault Priority: 3
                        Fault Frequency: 10
                        Reset counter: 49
                        Mileage: 174623 km
                        Time Indication: 0
                        Date: 2015.02.09
                        Time: 10:10:52
                 Freeze Frame:
                        Voltage: 12.10 V
                        Temperature: 10.0°C
                        (no units): 25.0
                        (no units): 11.0
                        Temperature: 11.0°C
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H17 0240
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0012121
       Shop #: WSC 02335 785 00200
       VCID: 3169F34FA8DC81962BD-8064
       Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0210
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H44 0390
       Revision: 00044000    Serial number: AUZ5ZBG3196719
       Shop #: WSC 00000 000 00000
       VCID: 1A3B34E3D56A62CE7A7-804F
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 42 AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0PLBFU
       Coding: 0013362
       VCID: 29591B2F800CF956E3D-807C
       Subsystem 1 - Serial number: 6332CSME17206C71/
       Subsystem 2 - Serial number: 6342CSME15507F7CE
       Subsystem 3 - Serial number: 6352QSME2610104F6
       Subsystem 4 - Serial number: 6362QSME24431B6BK
       Subsystem 5 - Serial number: 63734SME25547A573
       Subsystem 6 - Serial number: 63834SME225A18490
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H08 0230
       Revision: 00H08000    Serial number: 90026070690159
       Coding: 0002142
       VCID: E6C3D013D192962E8EF-80B3
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4F0 920 932
       Component: KOMBIINSTR. M73 H20 0170
       Revision: 00200000    Serial number: 5HP504H37
       Coding: 6185008
       Shop #: WSC 10197 599 68015
       VCID: 23450907E2202306A91-8076
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4F0 910 105 A    HW: 4F0 265 081 L
       Component: Heizgeraet      H08 0060
       Revision:        C    Serial number: 09011480
       Coding: 0000111
    Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B0730882E7
       Coding: F7599E7F303206
       Shop #: WSC 02334 785 00200
       VCID: ECD7A23BCF7EAC7ED8B-80B9
    Address 34: Level Control        Labels: None
       Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
       Component: J197 LUFTFEDER  H17 0060
       Serial number: 00619002978900
       Coding: 0000220
       Shop #: WSC 00011 888 06946
       VCID: 224B0C03FD3A2A0EA27-8077
    5 Faults Found:
    02646 - Plausibility of Level Control System
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 89
                        Mileage: 174643 km
                        Time Indication: 0
                        Date: 2015.02.10
                        Time: 16:09:43
    00453 - Function Limitation due to Over-Temperature
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174646 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 17:36:43
    01397 - Venting Solenoid for Level Control (N111)
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 89
                        Time Indication: 0
                        Date: 2064.00.00
                        Time: 00:00:00
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:17
    01316 - ABS Control Module
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:22
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 364CQ077650607
       Shop #: WSC 46566 133 83543
       VCID: 3B75D1677A907BC6811-806E
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174653 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:17
                 Freeze Frame:
                        Hex Value: 0x54DB
                        Hex Value: 0xEC99
                        Hex Value: 0x00B2
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 P    HW: 4F0 959 793 P
       Component: TSG FA          H12 0230
       Revision: 00-00000
       Coding: 0003626
       Shop #: WSC 02327 758 00200
       VCID: 377DCD5746B85FA6659-8062
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01037739670000
       Coding: 0402161
       VCID: 2E53E833B9E29E6E36F-807B
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    2 Faults Found:
    01403 - Glass-Break Sensors; Rear
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 49
                        Mileage: 100674 km
                        Time Indication: 0
                        Date: 2011.08.02
                        Time: 15:37:40
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 49
                        Mileage: 174623 km
                        Time Indication: 0
                        Date: 2015.02.09
                        Time: 10:10:28
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
       Component: Amp.-ASK-RD   H07 0270
       Revision: 08S00000
       Coding: 020001
       Shop #: WSC 02399 823 56573
       VCID: 285F1E2B5B06C05EFC3-807D
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000324356
       Coding: 0001113
       VCID: DEB3F8F309C2CEEE46F-808B
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 174652 km
                        Time Indication: 0
                        Date: 2015.02.11
                        Time: 23:58:00
                 Freeze Frame:
                        Voltage: 17.700 V
                        Temperature: 77.0°C
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 P    HW: 4F0 959 792 P
       Component: TSG BF          H12 0230
       Revision: 00-00000
       Coding: 0003626
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000321
       Shop #: WSC 02324 785 00200
       VCID: 204F060BF336381EB43-8075
    Address 55: Xenon Range        Labels: 8P0-907-357.lbl
       Part No: 8P0 907 357 F
       Component: Dynamische LWR  H02 0010
       Revision: 00000001    Serial number:
       Coding: 0000004
       VCID: 3D71DF7F648475F6BF5-8068
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 394C0077748892
       Coding: 0000001
       Shop #: WSC 02324 758 00200
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000044278
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  012403711
       Coding: 344630393135313035452056413030313234303337313120
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0003114
    Address 69: Trailer        Labels: 4F0-910-383.lbl
       Part No SW: 4F0 910 383 B    HW: 4F0 907 383 B
       Component: ANHAENGERELEKTR 003 0060
       Coding: 0000331
       VCID: 24470A1BE72E243ED0B-8071
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0050
       Coding: 0003114
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330707900511
       Coding: 0211416
       Shop #: WSC 131071 1023 2097151
       VCID: 285F1E2B9B06C05EFC3-807D
    1 Fault Found:
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 174642 km
                        Time Indication: 0
                        Date: 2015.02.10
                        Time: 15:57:51
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007645125
       Coding: 0010910
       VCID: 2C57E23B8FFEEC7E18B-8079
    End   ---------------------------------------------------------------------
    Last edited by Sam; 18-02-2015 at 09:59 AM. Reason: Adding code tags to prevent finger swipe/scrollwheel ache
  2. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Nov 2012
    Somerset UK
    Read my thread here:
    Multiple Overvoltage messages - Car died - scan attached - HELP!!
    In my case I had replaced my alternator with a second hand (not new) one, however the coils had failed on that and it resulted in multiple overvoltage messages. Can I ask if your alternator was a brand new or used?
    My recommendation would be to have the alternator referbished by a specialist if any of the error codes you've had are similar to those I had.
    I also suggest you add the model/engine size and year of your car in your signature strip (as I have done)
    Regards
    Mark
  3. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Jan 2015
    Belfast
    When the car is running can you put a voltmeter across the battery terminals to see whats happening, it should not really exceed 14v roughly, if higher the regulator on your alternator is faulty. The 17v indication is a good clue.
  4. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Oct 2014
    Romania, Vrancea
    Hey Mark my car is an 3.0 TDI 2007 ASB engine with 224 hp. I got the alternator changed at Audi one week ago brand new here is oe number 059903015RX of course to Audi dealer usually high prices, so i don't hope it is that one..... So the regulator should also be new then????
  5. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Nov 2012
    Somerset UK
    Yes a new regulator will be fitted to a new alternator.
    Am sure that an Audi dealership will only fit new, however compare your faults with mine, if they are similar I can only suspect that it is the althernator, which luckily Audi should replace for you free of charge.
    Doesn't mean that a new item won't be faulty
  6. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Oct 2014
    Romania, Vrancea
    I will go to Audi Monday and ask for a replacement, hope to solve it....
  7. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Oct 2014
    Romania, Vrancea
    So today the car was at Audi No error on Alternator so they will not re place it, the error on my car have not been often enough... So they cant fix it or replace alternator, ive seen on YOUTUBE it can be because of im not using AUDI battery i have now EXCIDE EK920 3 months old
  8. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Jan 2015
    Belfast
    A car battery is not going to generate 17 volts if that is whats happenign and its not a monitoring fault.
    Can you get a voltmeter or even better one of these
    Car LED Cigarette Lighter Voltage Digital Panel Meter Volt Voltmeter Monitor | eBay
    I have no connection to this seller and there are other sellers...
    Stick this in you cig lighter and when you have issues its an independent voltage measuring device, it should help.
    1 1 0
  9. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Nov 2012
    Somerset UK
    Quote Originally Posted by Bamse307 View Post
    I'm not using AUDI battery i have now EXCIDE EK920 3 months old
    Erm, perhaps you should have stated this from the beginning?
    According to google that battery is gel, specifically for 'stop/start car technology', and definately not for an 07 Allroad, please advise why you fitted it, or did a garage fit it for you?
    I may be wrong but am unaware of anyone with this age of car on this forum that has this type of battery fitted.
  10. Re: Plese help big problems with electronic issue on A6 allroad 2007 - Function Limitation due to Over-Voltage
    Oct 2014
    Romania, Vrancea
    It was fitted by a local work shop, so what you say more less is that the battery AGM type dont work properly on my car. I could understand that if it happened after i changed battery but the run on this battery in 2,5 month without any issue, then i changed alternator and all this started. Maybe becuase old alternator was warned out? that it worked together. What battery you propose????
  1. Electronic Steering Lock issue
    By Renesis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-10-2014, 02:30 PM
  2. Passat 2007 upgrade to Multi Function Steering Wheel Help.
    By Vadgama in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-10-2013, 07:32 AM
  3. Help Voltage Problems At Idle
    By Fishmaster-zero in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2009, 09:00 AM
  4. multi-function steering wheel for audi allroad
    By monkeyboyuk in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-07-2008, 02:12 PM
  5. Camber alignment - is it a big issue
    By blairmiller166@ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-06-2007, 12:11 PM
