Thread: My wife broke the car!!
Results 1 to 10 of 11
  1. Question My wife broke the car!!
    Aug 2014
    Huddersfield, United Kingdom
    I know I shouldn't let her drive it but it is her car so I can't really stop her.
    So here is the problem - my aftermarket radio has stopped working. Turned out to be fuse on the unit itself, however, it lights up but controls don't work. So I thought it would be an excuse to buy a new one
    And then, the rear wiper has started and won't bloody stop
    Has anybody got any ideas before I start thinking about main dealer expenses??!!
  2. Re: My wife broke the car!!
    Oct 2005
    'Your wife', uh huh, sure thing
    The wiper is one of three things; stalk, relay or motor.
    I'd start with the easiest and squirt some contact cleaner into the stalk base area and then operate the switch as normal. If that doesn't cure it, you can take it apart and give it a proper clean.
    If that doesn't fix it, check/replace the relay under the dash.
    If that still doesn't cure it, you'll have to remove and clean the motor but it's normally easier just to replace.
  3. Re: My wife broke the car!!
    May 2007
    17 Post(s)
    Four things...you forgot to mention the wiring that connect them all together so add a wiring loom to the shopping list
  4. Re: My wife broke the car!!
    Oct 2005
    Quote Originally Posted by Flash2 View Post
    No idea what you mean, there's never been a wiring issue in a VAG vehicle has there ?
    0 2 0
  5. Re: My wife broke the car!!
    Jan 2008
    Problems with rear wipers on these cars usually attributed to the screen wash leaking within the unit and frying the electronics within. Then it starts going a bit haywire, then stopping altogether. Replacement job.
  6. Re: My wife broke the car!!
    Aug 2014
    See, I was thinking about just changing the tailgate as my first job and then working my way down to the cheapest part. Good idea??!!
    Or I could just chop it in and get a Focus!
    On a serious note, with 2 electrical items going haywire at the same time, is there anything other than the entire loom that would connect them?
  7. Re: My wife broke the car!!
    Mar 2008
    Pembrokeshire
    Quote Originally Posted by Alfonzo View Post
    Shouldn't this be replaced at Audi's expense if that's the case......wishful thinking i expect
  8. Re: My wife broke the car!!
    Oct 2005
    Quote Originally Posted by Carew View Post
    On a vehicle that's at least 10 years old? Wishful thinking indeed.
  9. Re: My wife broke the car!!
    Apr 2014
    Try a new motor from the scrappies might be pretty cheap
    Using Tapatalk
  10. Re: My wife broke the car!!
    Feb 2015
    Sydney
    I'd suggest take it to a auto electrician leave it to the experts to rectify what the cause.
  1. Car vs Wife
    By MalcQV in forum Chat - Completely Off Topic
    Last Post: 13-07-2011, 09:45 PM
  2. My Wife's New Car!
    By Bristle Hound in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-09-2010, 09:29 AM
  3. The wife's new car.....
    By steve1234 in forum Q5
    Last Post: 06-07-2010, 10:39 PM
  4. My Wife's New Car!
    Last Post: 28-07-2009, 10:38 PM
  5. car from used car dealer broke. who pays bill??
    By churp in forum Chat - Anything with wheels
    Last Post: 18-05-2008, 03:23 PM
