Thread: 2002 A6 Rhd Comfort control module.
  1. 2002 A6 Rhd Comfort control module.
    Feb 2015
    United Kingdom
    Hi.
    Does anyone know the location of the Comfort control module on the Audi A6 2.5 allroad 2002 right hand drive estate. i have an issue with interior lights working whenever they please and the central locking switch on the drivers door wont lock the car when we are in it . so one thinks this module needs replacing.
    Just to add is it a big job.
    Thanks in advance. everyone.
  2. Re: 2002 A6 Rhd Comfort control module.
    131 Post(s)
    1979 Post(s)
    It is under the passengers side floor covering where you will find it swimming in two inches of water with a rotten red/black multiple power feed.
  3. Re: 2002 A6 Rhd Comfort control module.
    Feb 2015
    United Kingdom
    Swimming lol. The car does not look damp nor wet inside.. thank you ill be in there asap
  4. Re: 2002 A6 Rhd Comfort control module.
    131 Post(s)
    1979 Post(s)
    This picture is stored on my PC under the heading “Audi Allroad fish pond”, what isn't very clear is the 1 inch of water and completely sodden foam.
    The incontinence unit suffers from corrosion at this plug, where the constant live power pins are located which are red/blue, not the red/black as I said.
    This is called Q11, power comes down a 1.5-mm core from fuse 38 in the dash side and goes to pin 11 of plug 1 (black) as well as many other points such as the siren and ultrasonic unit. There is also another red/blue multi connection down there with a 1-mm core power feed wire called Q12 and the power is from fuse 14 and goes to pin 7 of plug 1 (black) and again, many other connections. Both these connections are described as " Positive (+) connection (30 a), in electric window/central locking and door contact switch wiring harness”.
  1. comfort control module
    By nigel63 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-01-2014, 03:31 PM
  2. Comfort control Module
    By Snaga in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-08-2012, 02:04 PM
  3. comfort control module
    By logic5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2010, 05:54 PM
  4. Please Help Comfort Control Module
    By VWP02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2009, 05:11 PM
  5. Where is my Comfort Control Module (CCM)
    By Digidick in forum Toledo
    Last Post: 24-10-2008, 06:22 AM
