Thread: audi coupe 16v timing chain
Results 1 to 10 of 10
  1. Question Re: audi coupe 16v timing chain
    Have started the timing chain replacement; have removed inlet manifold,and cam cover,about to remove cams and chain,what should the sprockets look like?,they seem to have rounded teeth,not like i expected;there seems to be wear in the teeth,the engine has done high mileage and the cam lobes do appear to have wear on them;what i don`t want to do is put the new chain chain on worn out sprockets,anybody got any advice?.
  2. Re: audi coupe 16v timing chain
    Jun 2007
    Gwent
    I've had 6 of these apart, they were all very rounded, not pointed like bike sprockets! If you can see the profile of the teeth is worn heavily one side then newer cams may be needed. From a performance point of view, now would be a good time to find some Volkswagen KR or ABF cams anyway. Other than that, have a look at it reassembled, see how much less slop there is in the new chain, hopefully you will be reassured.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Thumbs up Re: audi coupe 16v timing chain
    Hi there,could you give me some pointers on replacing the cams,i`ve tried a couple of times so far,trying to keep timing marks together when torqing down bearing caps is a pain;is there a method or is it simply a case of trial and error,appriciate any tips you might have.thanks.
  4. Re: audi coupe 16v timing chain
    Jun 2007
    Gwent
    I have changed heads over on 16v motor's not had the cams out so not run into this. I had no problems with the 20v, but it has a different relationship between the cam lobe centrelines, and the timing chain is at the front so it's easy to see what is going on.
    I'm guessing the cam(s) is turning before you can get the caps tightened down? I'm guessing that the cams which are pointing 'down' and making life difficult are at the back near the chain?
    I would try to torque down one cam first, if it turns as you do this, ensure that the other cam is allowed to turn by the same amount. When you torque the second cam down, they should still be timed to each other properly, just may not be at tdc? If it is too far out, you risk bending inlet valves. It might be a good idea to turn the crankshaft 90 degrees, while you get the cams right, at this point all pistons are halfway up/down their bores.
    If you can't get it by that method, still do the 90 degrees with the crank, then time the cams together in your hands, but turn them until the lobes on cyl 3 and 4 are NOT down. It should be easier to torque both cams down together, without losing their timing. Then turn the cams around until the timing marks line up and THEN TURN THE CRANK BACK BY THE 90 DEGREES, VERY GENTLY WITHOUT USING FORCE, if it won't go, turn the crank 270 degrees, the other way instead.
    To be honest, this is not good advice, but it is what I would try. If you are not clear what you need to do, please don't try this. I don't want you stuffing your motor because I did not type enough!
  5. Talking Re: audi coupe 16v timing chain
    Success!, cams are in and spot on first try;put the chain on the sprockets on the workbench(sprockets facing down)made sure the dots were lined up then dropped them into the head,checked to made sure they were still in right position then tightened the caps down;they were off after that but once i brought the camsprocket round to the tdc mark they were bang on;put all the rest of the stuff back on,all i have to do now is run the engine to fill up the tappets,should be ok after that,will keep you posted as to final conclusion,thanks for your advice.
  1. When to change Timing Chain on 2002 Polo 1.2 E 55 (AWY)
    By ettlz in forum Polo - Derby - Lupo - Fox
    Last Post: 25-12-2016, 09:48 PM
  2. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
  3. Timing Chain Problem
    By jonoharper in forum Touareg
    Last Post: 27-09-2007, 10:15 PM
  4. V5 Timing chain
    By Bryan20 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2007, 05:11 PM
  5. Timing chain tensioner
    By NIgolf in forum Passat - Archive Topics
    Last Post: 20-03-2007, 07:10 AM
