Thread: Engine Management Light - EGR Valve
Results 1 to 10 of 10
  1. Engine Management Light - EGR Valve
    Jun 2013
    Ireland
    Hello again,
    my wife was out with our Passat (2.0 170bp CR engine) over the weekend and the engine management light came on, the car lost all power so she pulled over and switched it off but when she started it again it was fine,
    I took it to a guy I know who plugged it in and he told me it showed a fault with the EGR valve, I'm told it got stuck!
    he said if it happens again I'll have to replace it and that it could stick again tomorrow or it might not happen for 6 months but basically drive on until then..... !!
    I don't know if this is related but the previous weekend the battery went flat all of a sudden, even though it was in daily use and showed no signs etc, so I jumped it and its been starting fine everyday since?
    any thoughts,
    thanks
    Rob.
  2. Re: Engine Management Light - EGR Valve
    Aug 2011
    Meath
    What were the fault codes? If you post the codes on here a pointy headed type will interpret them.
  3. Re: Engine Management Light - EGR Valve
    Jun 2013
    Ireland
    I don't know what codes came up, it was quick in & out job as he was closing for the day.... he didnt even charge me
  4. Re: Engine Management Light - EGR Valve
    Aug 2011
    Meath
    A dealer will charge you 80.00 yoyos maybe more. Look at this map for someone near you with VCDS where in Ireland are you? https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
  5. Re: Engine Management Light - EGR Valve
    Jun 2013
    Ireland
    I'm in Laois so either Sheehy in Carlow or Moores of Portarlington I presume...
    the guy I brought it to wasnt a dealer but does diagnostics, he didnt go into much detail about the fault other than saying that the last fault was showing up as EGR valve, he was that quick on his laptop that I couldnt read the code, lol
    can there be different fault codes relating to the EGR valve?
  6. Re: Engine Management Light - EGR Valve
    Aug 2011
    Meath
    It depends on what software he used to scan the car. You can get weird results with generic OBD scanners and the code you had could have been there for years. Look on done deal there's sure to be someone near you (usually Polish) that will have VCDS and can do a proper scan
  7. Re: Engine Management Light - EGR Valve
    Aug 2011
    Meath
  8. Re: Engine Management Light - EGR Valve
    Jun 2013
    Ireland
    thanks for that, they are not too far from me either,
    for what its worth the guy I brought it to was Polish and he had what I thought was VCDS, he plugged his laptop into the socket under the dash, I think my car details popped up on the screen before he looked for recent faults,
    my steering is slightly heavy in my opinion so he checked for faults there but found none.... he just said thats the way it is,
  9. Re: Engine Management Light - EGR Valve
    Aug 2011
    Meath
    If he had VCDS he should have gotten some live data
  10. Re: Engine Management Light - EGR Valve
    Apr 2010
    uk
    Mine is going into the garage on Monday for the same problem, last week it was on for most of the week then we drove 230 miles with one stop and no warning light, a short two mile journey the next day and it was back on again, then another 230 miles home and no sign of the infuriating little ****. Don't you just love these cars when everything is doing just what it should.
  1. Question Engine Management Light - EGR Delete with exisiting remap?
    By Graham_Smith in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-11-2014, 09:35 AM
  2. Engine Oil From EGR Valve
    By v1d2m3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-07-2012, 09:14 AM
  3. 1.0 MPi AUC engine, EGR valve problem?
    By Freeranger in forum Polo - Derby - Lupo - Fox
    Last Post: 13-05-2012, 07:03 PM
  4. engine management light on after egr block
    By teddy2k5 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-08-2011, 08:59 AM
  5. EGR valve removal AWX engine
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-02-2011, 06:55 PM
