Thread: C6 power steering fluid flush help?
  1. C6 power steering fluid flush help?
    Dec 2010
    Cambridge
    I've got some unusual noises that occur on full lock, loud groaning sound that is different to the ps pump under load.
    Fluid was at minimum so topped up but no improvement.
    Tried to siphon out old stuff which is looking black but filter mesh is blocking my pipe.
    Tried search but can't find any instructions, and not found anything of Web/tube.
    My electronic manual has instructions for bleeder the ps fluid but it's not quite what I want.
    Which I thought would be like engine coolant: drain it out, flush, top up and remove trapped air. Am worried about damaging ps pump.
    Any advice or links please?
    Car is A6 C6 2l TFSI.
  2. Re: C6 power steering fluid flush help?
    Jan 2011
    Stafford, UK
    This is how I did mine in post 10 - Power Steering Fluid
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: C6 power steering fluid flush help?
    Dec 2010
    Cambridge
    Hi Roy,
    Thanks, that's the similar instructions as from the electronic manual.
    So I presume by filling up the reservoir completely is why you can use a siphon (turkey baster).
    And after repeated lock to lock, the ps system is purged with new pas fluid, and you suck out the old pas fluid?
  4. Re: C6 power steering fluid flush help?
    Dec 2010
    Cambridge
    I found this video which helped me to understand.
    Audi VW power steering fluid flush DIY by Edge Motors - YouTube
    Thanks Roy, I'll order up some fluid and try this procedure.
  5. Re: C6 power steering fluid flush help?
    Jan 2011
    Stafford, UK
    Quote Originally Posted by garfayliu View Post
    Hi Roy,
    Correct.
    My son works in a repair shop and he just unscrews the lowest tube on the steering rack to empty all of the fluid, then refills.
    But he has the use of all the professional equipment,
    I don't.
  6. Re: C6 power steering fluid flush help?
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    What size are your wheels / tyres ? ...... You aren't running 19" wheels are you ?
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  7. Re: C6 power steering fluid flush help?
    Dec 2010
    Cambridge
    Hi, I'm running standard audi s lin e 18" alloys. Don't think it's tyre rubbing.
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. How Flush Power steering fluid Audi Q7????
    By Ricardodba in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 28-06-2013, 01:22 PM
  3. Replies: 1
    Last Post: 27-02-2012, 11:13 AM
  4. How To Flush your power Steering systemA8 (D3 Model)
    By happydan in forum A8 - S8 - V8
    Last Post: 26-02-2012, 08:05 PM
  5. How To Power Steering fluid flush
    By nd32 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2008, 03:29 PM
