Thread: turbo problems 2.0tfsi 2005 flat / no boost help
  1. turbo problems 2.0tfsi 2005 flat / no boost help
    Feb 2015
    uk bristol
    Hi can someone help I'm having issues with my car 05 tfsi axx engine , the car was previously a mates who noticed the car was not running correct so instead of looking into the issue he took it to street wise bristol and had "stage 2 " revo software put on the car around 4 months ago which he says did not change the cars power! When it was mapped they ran a vag com ill try attach pics code 008567 bank 1 , system too lean off idle .. also 000256 mass air flow , supply voltage intermittent which they cleared the codes , the car has the new rev d diverter as I fitted it last week which was not needed as it already had this also new pcv by what I can see ...is there any way telling what pcv I have ? Was told it was the newer one
    The car is like driving a 2.0 naturally aspirated car no pull as you'd get from a turbo .....in lower gears 3rd or 4th going slow and put your foot down you'd hear a slight (shhhh) from the turbo but no pull ... but if driven threw the gear it's as if I'm driving a standard 2.0L focus
    no lights on no codes appearing on snap on diagnosis tool
    I had the car up on ramps Saturday nothing looks out of place reved the car couldn't feel any air coming from any pipes ?? Does anyone have any suggestions it would be highly appreciated
  2. Re: turbo problems 2.0tfsi 2005 flat / no boost help help help ! :(
    Jul 2015
    south africa
    Air mass could be faulty. Causing the lean situation. Causing car to not pull. They don't always store fault codes as theyre not really broken per say. Its reagistering a signal but not accurately. Try swop it out first to test with working one
    From running car
    Sent from my GT-S5280 using Tapatalk
  1. Please Help S4 Turbo Boost Problems
    By OldBoy Racer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2019, 09:04 PM
  2. Please Help Turbo boost problems
    By mad max in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2013, 10:23 PM
  3. 2.0tfsi sportback turbo problems!!!!2005
    By efcste123 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-08-2010, 10:07 PM
  4. turbo boost problems
    By bigelv2002 in forum New Member Introductions
    Last Post: 14-12-2009, 03:27 PM
  5. Please Help Turbo lacks boost 2005 vw passat 2.0 tdi 140 bhp
    By iantomlinson in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2009, 03:37 PM
