Thread: Double Fault " Engine Fault - workshop & ESP Fault"
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Double Fault " Engine Fault - workshop & ESP Fault"
    Jan 2015
    Reading
    Hi guys,
    i have a 2009 Golf VW 1.6 TDI i only bought the car a few days ago, i went in a longish ride about 40 mins, and when i got on to my road i felt the car jerk and i thought i had stalled it, re-started the car, and i saw that the battery symbol and coil symbol were on, the car struggled to start up. anyways got it started luckily was close to home parked up and then i saw two faults appear on the dash, engine fault and esp fault. i turned the car off and now the car struggles a lot to start and when i do have it started it will just give up and turn off, i have to rev it to 2 to keep it from not switching off.
    I am planning to go to VW to get codes checked out, hoping that the car will drive to the garage.
    I just want to know if anyone has experienced this before and what it could potentially be.. any advise is welcome.
    i am absolutely gutted as i only just bought the car it has 75k on the clock.
    regards
  2. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    46 Post(s)
    Not saying that it is but your egr cooler has probably failed.
  3. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Jan 2015
    Reading
    Is this a big job to fix?
  4. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Aug 2011
    Meath
    Those cars can be costly to repair. Injectors, fuel pump and EGR & DPF are common and expensive failures. Get the scan done first look on this map for a site member near you that will scan your car https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
  5. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Sep 2008
    mostly in the garage
    Since you only bought it a few days ago I'd take it back and have a word with the seller.
  6. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Jan 2015
    Reading
    have already, obvously denied that there was a problem. and i cant prove anything really, i bought it private sold as seen..
  7. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Jan 2015
    Reading
    Got it booked for diagnostic tomorrow. Just tried to start and there is no engine fault message now. So hope I can drive it to the garage
  8. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Aug 2011
    Meath
    Quote Originally Posted by yusuf112 View Post
    Fault codes will still be stored so they can be retrieved and posted on here
  9. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Jan 2015
    Reading
    Btw is it safe to drive the car if there is an EGR failure? It's a few miles away
  10. Re: Double Fault " Engine Fault - workshop & ESP Fault"
    Sep 2008
    A failure of the EGR valve/cooler assembly won't cause any damage as such but the engine management will most likely default to 'limp home mode'. This means it continues to run but a reduced performance and should enable you to drive to the garage.
    Stopping and turning the ignition off and back on usually resets back to normal performance but often as soon as you try to apply any power limp mode cuts back in.
  1. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  2. "Engine Fault Garage" and coil light issue
    By daniel408 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-10-2013, 08:24 PM
  3. Question "Airbag Fault!" No ODB2 fault codes??
    By kipperphill in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-02-2013, 11:08 AM
  4. Please Help GT Tdi "Emissions Workshop" Fault
    By triggerhappy21 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2009, 08:31 PM
  5. Please Help Fault code "Emmissions Workshop!
    By AndyJug in forum Chat - Anything with wheels
    Last Post: 08-10-2008, 04:36 PM
