Thread: Passat door lock problem.
  1. Passat door lock problem.
    Jan 2015
    Ireland
    Hi, my passat drivers door is acting up. The door opens and closes when the car is unlocked. If I lock it and unlock it the drivers door will not open from the inside or outside unless i put down the window at which point it will unlock. The other doors are all fine.
    Not sure if its a common problem and I am hoping that someone could help me with the issue or point me in the right direction.
    Thanks, Alex
  2. Re: Passat door lock problem.
    Mar 2008
    Leiderdorp, Netherlands
    It is most likely the door lock that is playing up. On the older models the solder joints crack (develop dry joints) and cause all sort of strange behaviour. I had something similar on a MK4 Golf. To fix the problem I could either replace the lock (very expensive) or fix it by removing, opening and re-soldering all the sensor joints. I don't have the step by step guide anymore but if you do a search you should find something. (Externally the lock mechanism for the golf and 2003 Passat look exactly the same so I am assuming similar problems and solutions).
    Having said this, it would worth checking and cleaning all connections before messing with the lock. If it is the actual lock you should pick up an intermittent error when doing a vag scan.
  3. Re: Passat door lock problem.
    Jan 2006
    Near Basingstoke
    I had problems with the central locking on my doors when I had the water ingress issue. Check that you do not have damp carpet in the front and rear passenger footwell. If wet see the many threads on here...
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Question Passat B5 door lock/catch
    By zedf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2010, 08:14 PM
  3. Mk V Door Lock Problem
    By tosalet1 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-12-2009, 02:44 AM
  4. passat rear door lock problem
    By wmcalin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-10-2009, 12:47 PM
  5. Passat passenger door lock!
    By peagreenpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-10-2009, 04:24 PM
