Thread: Passat 140 poor cold start
  1. Passat 140 poor cold start
    May 2013
    Swindon
    For a while now my Passat BKP has had a intermittent cold start issue. Some mornings it will crank into life first turn but sounds sluggish and other mornings it will fire and die but will start on second turn straight away. Car runs fine and starts fine once warm but can still be a bit sluggish to start. I have changed the plugs so that can be ruled out along with temp sensor. I have seen a clip on youtube of a Passat that starts the same as mine and turned out to be the in tank fuel pump. Is there a way of testing the fuel pump as it makes a noise when ignition is on but not sure if its causing fault.
  2. Re: Passat 140 poor cold start
    SE London
    It's the filter in the fuel pump. It's not an independantly changeable item -- from the one I saw when I went to a Golf TDi.
    They get gunked up the sides so sometimes allow fuel through, sometimes not enough. You can check fuel pressures in VCDS
    but as I'm not a Derv head have never had to to it.
    There have been reports too of supermarket soup causing bad firing. But again, me being petrol, no direct experience
  1. A3 2.0tdi 140 poor cold starting
    By Scottm88 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-08-2014, 11:39 AM
  2. passat tdi 170 poor cold start and smoke
    By l200jmc in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-12-2013, 03:16 PM
  3. V6 4motion poor cold start
    By katmart in forum Golf MK4 - 1999 - 2004
    Last Post: 25-01-2009, 09:11 PM
  4. Poor cold start - gti
    By D'Squared in forum Golf MK3 - 1993 - 1999
    Last Post: 17-02-2008, 12:20 PM
  5. 02 V6 4motion poor cold start
    By katmart in forum Archive posts
    Last Post: 29-12-2007, 06:27 PM
