Thread: Smearing wiper? common issue?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. Smearing wiper? common issue?
    Jun 2010
    Driffield , East Yorkshire
    my drivers side wiper leaves a tiny smear on the return wipe down, nothing on the blade or under the blade. its almost like a 'film' of polish etc. i have washed it, used autoglym on it etc. still there. i went to vw and they told me its a known issue and cant be fixed yet, but it does dissapper eventually. they have the same issue on there demonstrator and 2 of there staff cars.
    has anyone else got/had the same issue.?
  2. Re: Smearing wiper? common issue?
    Aug 2011
    manchester
    Quote Originally Posted by andyo33 View Post
    There,s a thread on another forum that says VW are aware of the issue and are in the process of a re-design of the drivers side wiper blade so it,s just a matter of wait and see for now.
  3. Re: Smearing wiper? common issue?
    Jun 2010
    Quote Originally Posted by ept55 View Post
    thanks, pretty much what the guy at vw said, but he didn't mention (or didn't know) of the redesign. it seems to be the area in alignment with the arm / blade attachemnt point. could you point me in the direction of the other forum, jsut so I can follow the feed?
    thanks
    Andy
  4. Re: Smearing wiper? common issue?
    Aug 2011
    manchester
    thanks
    Andy
    Hi Andy it's www.golfmk7.com the thread is things that annoy about the mk7 hope it,s helpful to you.
  5. Re: Smearing wiper? common issue?
    Apr 2013
    oxford uk
    Inoticed this in the heavy rain last saturday, i,d like to try a different blade, i think someone has fitted a bosch blade with some success!
  6. Re: Smearing wiper? common issue?
    Nov 2009
    Yep - same problem
    Dealer has changed blade but, if anything, it now seems slightly worse.
    They told me they had not come across it before and VW did not have any knowledge of the problem. Someone's not being completely honest it seems.
    They've gone back to VW and I'm waiting to hear what the fix suggestion is.
    Golf MK7 1.4 Tsi GT DSG
  7. Re: Smearing wiper? common issue?
    North Shields, UK
    I had the exact same issue with my Scirocco. Smear on the drivers side around the middle of the swept blade area, at the hinged knuckle. I had a few replacements done by the dealership (they will only cover you for a few thousand miles before they blame "fair wear and tear" so let them know early that they're not performing correctly), but same issue. It's the crappy Valeo wipers they fit as standard. Went to Bosch Aerotwin wipers and never looked back.
  8. Re: Smearing wiper? common issue?
    Jul 2009
    London uk
    I have been tweeting VW and they did call me be back several times and made sure I was booked in with a dealer. They are aware of the issue but not aware of a blade design. They do however think they have a fix and VW dealers have been issued with a screen paste and a "special cloth" but she said it was the cure. I am waiting for a courtesy car so it will be a couple of weeks yet to see if it does what it says on the tin.
    Golf MK7 1.6 TDi SE DSG 5 Door Tungsten Silver
  9. Re: Smearing wiper? common issue?
    Mar 2010
    London
    Pratting about addressing symptoms isn't going to be a permanent fix......we're talking potential MOT failures so VW best get their skates on before they're forced to issue a recall.
    TSI 1.4 SE DSG
  10. Re: Smearing wiper? common issue?
    Jul 2012
    Hampshire, UK
    Has anyone managed to change the OEM wipers for Bosch Aerotwin ?
    The reason I ask is that I ordered a set from wiperblades.co.uk with the universal fit (including push button), but low and behold they don't fit ... Seems VW now use a narrower and shallower version of this type of fitting on the Mk7. WB very helpful and sent out another set of Aerotwins with a slightly different version of the push button, but these don't fit either. Keen to solve the problem, they then sent out a set of Lucal push button fit wipers, which are narrow enough, but, you've guessed it, not shallow enough (maybe just as well as Lucas don't do too well in any test I've seen). So back to the drawing board with WB.
    If anyone has managed to source some decent replacement wipers, I'd love to know what they are.
    Mine - 2011 A7 3.0 TDi Quattro SE
    Hers - 2013 Mk7 Golf GT 1.4 DSG
  1. Audi tt - Odometer issue - is it common?
    By Ben Buhagiar in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 07-04-2013, 09:21 AM
  2. Just how common is the porous head issue?
    By danb986 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-04-2011, 09:46 PM
  3. Front Spring Sheared - Common issue?
    By Rsjm5632 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2010, 10:36 PM
  4. The dreaded wiper issue
    By Dozz in forum Alhambra
    Last Post: 03-10-2009, 01:50 PM
  5. Is this common? A4 WIPER ARMS CORROSION
    By dkb18155 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2009, 10:24 PM
