Thread: Head clean and rebuild 1.8 8v
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    So my head gasket went the other day.
    So I thought. While it's apart I might as well strip it and clean it properly.
    Will continue cleaning on Monday send it off for skimming and pressure testing. then to lap in the valves and change the valve stem seals and it's ready to refit.
    2 3 0
  2. Re: Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    So I came across a problem this morning. 2 of the 8 new valve stem seals are damaged. Does anyone have any laying around or no a good place to pick them up?
  3. Re: Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    Started cleaning the head. Some of the water ways are looking a little worse for wear but haven't wrecked the head.
    On to cleaning the block today as the head is off to be skimmed.
    0 2 0
  4. Re: Head clean and rebuild 1.8 8v
    Aug 2011
    Meath
    Did you get the valve stem oil seals? A dealer should still be able to source them or a factor. The head cleaned up well, where did the gasket blow?
  5. Re: Head clean and rebuild 1.8 8v
    7 Post(s)
    The stem seals should come with the head gasket set.
    1 1 0
  6. Re: Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    They did. But where broken. I've got a new set now but struggling to get the old ones out now.
  7. Re: Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    So got the head back. It's all flat and no need to skim.
    can you guess what I forgot to insert before the stem seal.
    Just got to put the camshalf back on and then back onto the block.
    Having trouble finding the torque settings as for some reason my Haynes (*****) manual doesn't acknowledge the year of my car.
  8. Re: Head clean and rebuild 1.8 8v
    Aug 2011
    Meath
    Stage 1 40 nm, stage 2 60 nm, stage 3 180 degrees
  9. Re: Head clean and rebuild 1.8 8v
    Jan 2015
    Southampton
    Cheers. I will get it all torqued down in the morning.
  10. Re: Head clean and rebuild 1.8 8v
    Aug 2011
    Meath
    Is she running ok now?
  1. Low power after head rebuild
    By ryan1396 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2015, 09:29 PM
  2. Little help, lifter noise/rebuild head
    By babygirl25stl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-10-2014, 11:09 PM
  3. Head rebuild after cam belt breakage
    By driver2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-02-2010, 09:28 PM
  4. Question Golf 1.4 16v AHW head rebuild - average cost?
    By TheCrust in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2009, 08:24 PM
  5. How to clean and keep clean Light Beige Phoenix Cloth interior
    By ackerman821 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 04:36 PM
