Thread: Passenger Door will not unlock with Remote
  1. Passenger Door will not unlock with Remote
    Mar 2010
    saltash uk
    Any ideas?, my passenger door on my 59 plate A6 Avant will not unlock via the remote key fob or by the unlocking button on the drivers door. The only way that the door can be unlocked is by using the lever on the inside of the passengers door. I have tried changing the setting on the MMI, but this makes no difference. The door locks fine via the key fob and automatically once you start moving. It is beginning to annoy me now!!
    Any help will be gratefully appreciated.
    2009 Audi A6 Avant 2.0L Tdi
    2010 Audi A3 2.0L Tdi
  2. Re: Passenger Door will not unlock with Remote
    46 Post(s)
    You'll probably find you need a new door lock/catch.
    A fault scan should confirm this but in the meantime check the wiring is secure on the grommet which runs between the body and door.
  3. Re: Passenger Door will not unlock with Remote
    Mar 2010
    saltash uk
    As always, Very Many Thanks Chris ;-)
  4. Re: Passenger Door will not unlock with Remote
    Jan 2011
    Stafford, UK
    Quote Originally Posted by rnblade69 View Post
    Look here - Passenger door, intermittent unlocking
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  5. Re: Passenger Door will not unlock with Remote
    Mar 2010
    saltash uk
    Holy ****!! Just read through that!
    if it is what you very knowledgeable gents predict, I'm not looking forward to the bill :-(
  6. Re: Passenger Door will not unlock with Remote
    May 2014
    Darlington
    78 Post(s)
    If you good with the spanners then it's an easy DIY job, did a quick write-up here Driver's door won't unlock
    3 2 0
  7. Re: Passenger Door will not unlock with Remote
    Jan 2011
    Stafford, UK
    And the scary bit is, there are four doors
  1. Passenger door wont unlock
    By Hobb99 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2013, 05:50 PM
  2. Replies: 0
    Last Post: 07-02-2012, 12:25 PM
  3. Passenger Door won't unlock
    By broken_nail in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-06-2010, 03:28 PM
  4. Please Help Passenger door lock/unlock
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2008, 02:56 PM
  5. passenger door will not unlock
    By photogr22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-04-2007, 10:52 PM
