Thread: Passat 2.0 tdi sel cold starting problem
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Passat 2.0 tdi sel cold starting problem
    Dec 2014
    Loughton
    Quote Originally Posted by martin1810 View Post
    If you have steam from the exhaust the coolant level must go down. Unburnt diesel looks like white fog and smells...mostly like unburnt diesel. These engines must have correct NGK glowplugs and correct controller with no errors. Did you fit new injector seals with injectors. These must be replaced carefully.
    Hi there. I fitted the injectors as they came out. I had the car plugged onto vcds the morning and found lots of codes off whitch most cleared but one. Injector four fault p1269.
    I have a set off 140 injectors 03g130073s i would like to try instead off the 03g130073t thats in the car. Do you think that they are compatable? Or will i cause damage.
    Thanks Jaco
  2. Re: Passat 2.0 tdi sel cold starting problem
    Oct 2023
    Hungary
    Quote Originally Posted by Jaco1979 View Post
    Thanks Jaco
    Hello. did you manage to find the p1269 error code?
  1. Please Help Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    By jwalman in forum Golf MK5 - 2004 - 2009
    Last Post: 10-05-2015, 12:25 PM
  2. Passat TDI 170 SEL estate
    By LEE scaff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-09-2008, 01:59 PM
  3. Please Help Passat TDI 170 SEL 2007
    Last Post: 05-09-2008, 01:52 PM
  4. Vw Passat Tdi 170 Sel 2007
    Last Post: 05-09-2008, 06:01 AM
  5. VW passat TDI 2003 cold starting
    By dustybus in forum Archive posts
    Last Post: 19-12-2007, 03:12 PM
