Thread: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
Results 1 to 10 of 12
  1. Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Audi A6 / 2007-8.
    The MMI system is 2G (mono), with Navi and 6 disk changer.
    In order to prepare for a retrofit of a Visseo MOSTO Bluetooth, a software upgrade was performed, as it was showing C6StdNavi_0410 which was too low.
    The SW Update was S1-C6-EU-K310.
    Now, the system restarts every 5 mins (almost exactly 5 mins), and the Sat Nav no longer functions at all, nor will it read any disk. The reported error appears to be an application upgrade problem.
    CD and radio are fine (apart from rebooting every 5 mins, and dont' always come back on the same station/channel etc)
    It think this looks like the Navi unit is basically not booting.
    I believe that in this system, the Navi unit is the master, as isolating it (MOST bypass cable), causes nothing to boot.
    There was nothing wrong with the Navi unit prior to attempted upgrade.
    I'm struggling to find a expert afermarket Audi MMI speclialist, so hoping someone can help.
    I can provide error screens/logs/ F/W versions if necessary, and have Can-HEX cable and VCDS 12.10
    From memory, the recorded error in the InterfaceBox Error screen is SVM_Syncro
    (PS Viseeo-MOSTO not fitted yet),
    thanks for any help, or recommendations.
  2. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Just adding the following : (note that CD and radio actually working fine)
    Control Module Part Number: 4L0 910 468 A
    Component and/or Version: J533__Gateway H06 0060
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(Std Navi) OK OK
    0E-Media Player 1 ERROR ERROR
    1E-Media Player 2 OK OK
    47-Sound System OK OK
    56-Radio ERROR ERROR
    37-Navigation ERROR ERROR
  3. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Jan 2012
    Coding Something
    Did you have the car running when it was being updated?
  4. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Yes - the car was running as it upgraded.
    Some more details : upgrade disk was 4L0998961 (1 of 3)
    I've done some digging around the SWUPgrade logs, and it looks like gateway is showing the error, despite the fact that it seems to work perfectly (for 5 mins and it's the Sat Nav that won't initialise or read disks. It reports a problem on the SPN - does anyone know what that is:
    See below for the logs walkthrough I captured (the final file won't attached and shows download error 0xffff)
  5. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Jan 2012
    Coding Something
    It looks like a non complete upgrade tbh, can you force a fresh upgrade & see if it takes better.
  6. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    46 Post(s)
    4L0998961 are mmi 2g high discs. you have 2g basic.
    1 1 0
  7. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Jan 2012
    Coding Something
    Good spot, my only excuse is the poxy flu I've had for 2 weeks now, argghhhh
  8. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    46 Post(s)
    i struggle with a cold let alone flu!
  9. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    Jan 2012
    Coding Something
    Went to Italy to spend time with my daughter, come back with a socalled cold & been really ill ever since, thanks my beautiful Issy lol.
    Its one of the worst ones I've had, my partner has it now & she's walking about, working etc, its literally knocked me of my feet, oh well life rolls on.
  10. Re: Audi 2G MMI Basic Plus (Navi), constant reboot after upgrade
    SO yes - I think it looks like a failed upgrade - but I cannot force it again, as the Navi unit will not read any disks at all.
    On the topic of the correct disks, I spend an age following dozens of threads, and it is really confusing to find the right versions/types, because of all the combinations. However, I believe that disk 1 of this set does contain the Basic Plus update (I checked the meta file).
    Either way, I would have expected it only to attempt an upgrade of the applicable binary to the correct target module - thats surely the purpose of the meta file.
    So - given it's clearly in a confused state, how does one update a unit, other than with the Navi unit. It seems unbelievable to me that a module cannot be programmed either off the car, or via CANbus, or other diag port - and such a process should be quick, easy and cheap (I am software engineer, by profession, working on embedded hardware systems, so i design this kind of thing - The modules must be reflashable).
    Or is this something that Audi keep to themselves for revenue reasons? I've looked at the costs of 2G/3G upgrades etc, and replacement modules; This stuff is not exactly high cost equipment,and should be a few tens of pounds, but it stretches to thousands, because of the market, otherwise I'd upgrade the whole lot to 3G.
    But surely someone knows, and has the capability, to reflash the modules for a reasonable cost?
    Any other thoughts on how I get this working again?
  1. MMI Basic to MMI High upgrade
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-07-2018, 12:41 PM
  2. mmi 2g from basic plus upgrade problem :(
    By jocker01 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-12-2013, 04:28 PM
  3. Audi Q7 MMI 2G Basic replacement/upgrade in London area?
    By musa92k in forum In Car Entertainment
    Last Post: 03-07-2013, 11:49 AM
  4. MMI basic to MMI high upgrade,components equipement
    By coconut in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-09-2009, 02:23 PM
  5. 2005 A6 MMI basic upgrade
    By Izzy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-07-2008, 11:36 AM
