Thread: Changing a battery
Results 1 to 10 of 13
  1. Changing a battery
    vespa Guest
    This may sound a stupid question, but is changing the battery straight forward ie undoing the two contacts +/- and securing plate and nut. Or is it more involved such as reprogramming the radio etc if power is interrupted? (nothing seems straightforward these days)
    Car 2.0Ltr TDi Highline 140 2009
  2. Re: Changing a battery
    Dec 2010
    Worcs, UK
    Is it a blue motion model with stop start?
    If yes then you will need to code the new battery in energy management control unit (you need a battery with a special code on it too).
  3. Re: Changing a battery
    vespa Guest
    Quote Originally Posted by itavaltalainen View Post
    No, it is a Highline DPF fitted with the satnav console. I have read that it will need the reprog of the satnav/radio and something to do with windows and doors.
  4. Re: Changing a battery
    Dec 2014
    sweden
    Changed the battery on my 06 2liter 140 tdi comfortline wagon. Just disconnected the terminals removed the holder plate, fitted new battery no need to reprogram anything apart from the clock, got a few warning lights but cured this by driving ~100 meters.
    No other problems.
    Hope this helps.
  5. Re: Changing a battery
    Dec 2010
    Worcs, UK
    push the window switch till windows are completely down, then up switch till they are completely up again.
    sat nav you may need to reset clock, not sure what else would need resetting.
  6. Re: Changing a battery
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by skomedal View Post
    No other problems.
    Hope this helps.
    Same car, and no problems - although I seem to recall that I did have a problem undoing the bolts holding the terminal clamps. Can't remember why.
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Changing a battery
    Dec 2014
    sweden
    Quote Originally Posted by Quatrelle View Post
    Think you had problems removing the the battery holder plate, this space is very access restricted if you do not want to loose the bolt and plate into the engine well.
    Solved this by inserting a small neodymium magnet into the socket wrench whilst using a very large neodymium magnet on thick fishing line on the plate itself, same in reverse when fixing in place again.
  8. Re: Changing a battery
    Feb 2014
    Leicestershire
    19 Post(s)
    There is 'setting saver' devices which are basically a coffee mug sized 12v battery with wires and little crocodile clips. You clip it on the leads then remove the leads from your main battery and you loose no settings.
    As technology moves on and ECM's monitor battery voltage, these simple aids are going to become obsolete though!
  9. Re: Changing a battery
    vespa Guest
    Thank you all for your input on this. It used to be a simple matter of changing a battery but as technologies have progressed there seem to be laots of little extra bits to consider.
  10. Re: Changing a battery
    Feb 2014
    Leicestershire
    19 Post(s)
    Quote Originally Posted by vespa View Post
    Definately!
    I had a MK4 golf before my A4, I'm gutted how integrated the audio is in comparison. All the CANbus communication makes it super expensive to upgrade.
  1. changing battery does it need to be so difficult?
    By vinpetrol in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2012, 11:16 AM
  2. Changing battery on A4 B6
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2010, 07:13 PM
  3. Question Changing my Battery
    By andrewtransport in forum The Commercial Range
    Last Post: 21-02-2009, 11:49 PM
  4. Battery Changing
    By theskyfox in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2008, 01:59 PM
  5. Changing Battery on 1.8t
    By Janusian in forum Passat - Archive Topics
    Last Post: 24-12-2006, 10:17 AM
