Thread: Strange limp mode occurance.
  1. Strange limp mode occurance.
    On the way to work the other morning, gentle exceleration up the road and suddenly it went into mode after changing into 3rd!
    I stopped engine, turned key and all back to normal.
    It didn't overboost as I was only on light throttle at the time (engine was stone cold).
    All the vacuum pipes on the engine are fine and it never showed any CEL!
    Any idea's folks? its a PD AWX.
    Ironic that my older 03 plate that ive had for 8 years and done 176'000 miles has never missed a beat- once!
    Another little issue I have with my 'new' Passat 1.9 pd is that the revs tend to hang between gear changes whilst my old one doesn't do it.
    Hunted all over for answers and cant find anything on it.
    I'm starting to think this is linked to my intermittent limp mode issue.
    Until I get VCDS on it I know im limited in fault finding but wondered if there's anything common I could try swapping from my old car.
  2. Re: Strange limp mode occurance.
    46 Post(s)
    Even though there is no eml there is still a code in the ecu, get it scanned for faults.
  3. Re: Strange limp mode occurance.
    Yeah, thanks Chris, probably the best course of action I guess!
  4. Re: Strange limp mode occurance.
    Even stranger, scanned it for DTC' and it found 18263 which is the ignore code, probably because I changed the battery a couple of weeks ago and
    19586, EGR over limits because I drove it with the EGR vac pipe off a couple of weeks ago by accident.
    Apart from those, nothing!!
    Don't think I'l worry to much unless it becomes a habit.
  1. Replies: 5
    Last Post: 07-02-2013, 06:52 PM
  2. help needed = Limp mode with strange characteristic
    By besian in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2012, 12:32 AM
  3. Question Limp mode/safe mode
    By fourringsrus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 02:06 PM
  4. Strange limp mode
    By danielintheuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 09:35 PM
  5. Strange Occurance With My Electric Windows
    By pedropete27 in forum Bora - 1998 - 2005
    Last Post: 04-03-2008, 12:05 PM
