Thread: 7 Fault Codes No Management Lights
  1. 7 Fault Codes No Management Lights
    Jan 2015
    Leigh England
    Hello,
    As Title i have run a diagnostic and got 7 codes car runs under power , bad starting (if it starts) and idle is very rough .
    codes are
    I have ran a code check and got 7 codes below.
    10501 ?? can not find any information
    17668 PD Unit Injector Cylinder 1
    17671 PD Unit Injector Cylinder 2
    17672 PD Unit Injector Cylinder 2
    17674 PD Unit Injector Cylinder 3
    17675 PD Unit Injector Cylinder 3
    17678 PD Unit Injector Cylinder 4
    Just had a new loom fitted at VW week ago
    ?? any ideas
    Aswell does anyone know of a good VAG specialist near (leigh Warrington Manchester) ??
    Thank You
  2. Re: 7 Fault Codes No Management Lights
    Jan 2015
    Leigh England
    Vw have just been on and informed me that it will be 3 new injectors needed 2 and 1/2 years after they was all done on the recall . £1472
    Think i will strip the car down tonight and try find someone that repairs the injectors.
    Does anyone now of such place ??
  3. Re: 7 Fault Codes No Management Lights
    vespa Guest
    Was it recalled at the time of injector recalls? You can check on VW's official website ( Check for Safety Recalls : Volkswagen UK ) Get on to VW customer services and see if they will give any goodwill payment. Try Corkills in Wigan, who I have found helpful over the past 4 years and who service my car. They are someone I feel that I can trust. Steve Keenan is the service manager or just go through to service reception
  4. Re: 7 Fault Codes No Management Lights
    Jan 2015
    Leigh England
    Yes was done on the recall in june 2012 . all new injectors and new loom.
    Just had loom replaced and now they say it is 3 new injectors required .
    they told me they have asked for goodwill but been told because it is out of the 2 year warranty they are unwilling to do this.
    Don't feel like i am getting a very well built car if i can expect new injectors after 30k and 2n1/2 years.
    Unhappy.
    Can anybody repair these ??
  5. Re: 7 Fault Codes No Management Lights
    vespa Guest
    Quote Originally Posted by hazza171 View Post
    Unhappy.
    My car was 6 years old and the rear light clusters were failing again. I contacted VW directly at their customer services and got a goodwill gesture on yet another set supplied and fitted by Corkills. Yes I had to put some money towards them but I still managed to get goodwill from VW. I have had the car from new but the original supplying dealer I had no confidence in so have been dealing with Corkills for around 4 years now. Contact VW in Milton Keynes and see what they say. If that fails why not bung a good injector cleaner through the system? as long as it is not an electrical fault it may just clear any blockages if there are any. If they are useless now then you have nothing to lose.
  6. Re: 7 Fault Codes No Management Lights
    Up North
    I don't wish to suggest that there has been any jiggery pokery here, but there are stories aplenty of injectors and wiring looms for sale on auction sites that, it is alleged, didn't get fitted under the recall but instead made it to the bottom of a mechanic's toolbox.
    It wouldn't be a bad idea to get someone to check model numbers of the existing injectors against those supposed to be replaced and maybe also if there is any identifying info on the loom. Crasher is probably ideal if you are not too far away from his premises.
    Just a thought.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. Engine Management MIL on with the following codes - any help appreciated.
    By xouser8334 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-10-2014, 08:26 PM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. Question Dash Lights, Fault Codes = A confused me?? Any1 help??
    By indi1183 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-05-2012, 04:00 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. engine management fault codes
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-03-2008, 07:13 PM
