Thread: Mk4 Golf, Heater only Blows cold air!!!
  1. Mk4 Golf, Heater only Blows cold air!!!
    Sep 2007
    I have a 1999 Golf 18gti 20v the problem i have is that when i put the heater on it only blows cold air however hot i put the temperature up to, the car has climate control but this also only blows cold air. Wondered if any one has had the same problem and if anyone has any ideas how to fix it.
    Thanks in advance for any help.
    Nobby
  2. Re: Mk4 Golf, Heater only Blows cold air!!!
    Dec 2006
    Manchester
    Quote Originally Posted by nobby999 View Post
    Nobby
    Sounds like either a blocked heater matrix, or a failed actuator.
    After a run, carefully have a feel of the pipes in the engine bay as they pass through the bulkhead (the one feeding the matrix).
    If there warm, then i'd put it down to an actuator.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Mk4 Golf, Heater only Blows cold air!!!
    A, A
    Welcome to the forum mate,
    Could also be a stuck flap motor behind the dash only letting in outside air.
    If you could get a VAG COM on it, it might tell you the problem.
    Mine sometimes sticks on HOT air only, but sorts itself usually next time i use it.
    VAG COM shows.
    01271 - Positioning Motor for Temperature Flap (V68)
    37-00 - Faulty
    This is an expensive job to sort but only happens very rarely and a "flap motor reset" using a VAG COM sorts it to.
    Just another B7 Estate
  1. Polo Heater cold at tick over
    By GrahamS in forum VCDS - General Questions
    Last Post: 25-08-2011, 08:21 PM
  2. golf mk III heater
    By garyhughes in forum Golf MK3 - 1993 - 1999
    Last Post: 07-07-2008, 10:22 AM
  3. TDi Engine hose blows off at 3000rpm!
    By DaveJB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 12:47 AM
  4. Cold heater at tickover speads
    By GrahamS in forum Polo - Derby - Lupo - Fox
    Last Post: 15-12-2006, 10:41 PM
  5. 2006 Climatic Problems - Blows Cold, but cabin hot?
    By longboyad in forum Passat - Archive Topics
    Last Post: 17-07-2006, 08:51 PM
