Thread: Tyre Wear - How many miles on a set?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. Tyre Wear - How many miles on a set?
    May 2013
    Rugby, UK
    12 Post(s)
    I know this has been discussed on the forum before, but thought a fresh post would be simpler.
    I have a 2.0D S Line Avant Multitronic with S-Line suspension and 19" wheels that has just had it's 2nd service by Audi at 38,000 miles (it's 19 months old).
    They have advised that the tyres are 3mm all round. I'm really confused by this as they are the original tyres (Pirellis). Shouldn't the front tyres wear out quicker that the back?
    Almost all my mileage is on the motorway.
    My last A6 managed around 25k on the front and 50k on the back when I changed them at around 2-2.5mm.
    Any thoughts?
    2017 model A6 Avant Black Edition 3.0Tdi (272) Quattro, Sepang Blue Exclusive Paint, Tech Pack, Matrix LEDs, Ambient Lighting, 20" 5 Twin Spoke Wheels, S Line Suspension, Audi Smartphone Interface, Debadged
  2. Re: Tyre Wear - How many miles on a set?
    46 Post(s)
    38,000 on 19" tyres is exceptionally good.
    What was your last A6 in terms of engine, trans, tyre size etc?
  3. Re: Tyre Wear - How many miles on a set?
    May 2013
    Rugby, UK
    12 Post(s)
    My last one was an 56 2.0D S-Line Avant manual with S-Line suspension and 18" wheels. The tyres were continentals (I remember because I had to put 4 on it a couple of months before I sold it!)
  4. Re: Tyre Wear - How many miles on a set?
    46 Post(s)
    The bigger the wheel the less miles you'll get, your older car would've been lighter too.
    Did you check the wear ratings for both tyres? You'll probably find the Pirelli has a smaller treadwear rating compared to the Continentials.
  5. Re: Tyre Wear - How many miles on a set?
    Dec 2006
    There are so many factors, road surface type, pressure, compound,size, temps, tyre model (dot) etc etc..
  6. Re: Tyre Wear - How many miles on a set?
    Feb 2013
    Gloucester
    57 Post(s)
    Have you got quattro? Could be why they are all wearing at the same rate?
  7. Re: Tyre Wear - How many miles on a set?
    Oct 2014
    LA,CA,US
    Quote Originally Posted by Chris View Post
    I'm not convinced: a larger circumference will require far less rotations and therefore reduced contact per square inch of tire over a certain distance. Older cars are typically heavier than their modern counterparts too.
  8. Re: Tyre Wear - How many miles on a set?
    Tripletrouble Guest
    18k if I'm lucky. Mostly motorway miles.
  9. Re: Tyre Wear - How many miles on a set?
    Apr 2009
    Surrey
    183 Post(s)
    I changed the front 17" Pirellis on my 2.O Manual Avant SE at 26k, the rears are about 50% worn
  10. Re: Tyre Wear - How many miles on a set?
    Aberdeen
    63 Post(s)
    Good mileage and probably because you are doing mostly motorway. Not so many corners to scrub them on and pulling away and stopping at lights etc.
  1. Question 20k miles on a set of tyres?
    By djmx5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2014, 11:18 AM
  2. Tyre wear..
    By wedgie7 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-08-2013, 09:37 PM
  3. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  4. Tyre wear: 20,000 miles on rears?
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2009, 08:47 PM
  5. How many miles on a set of tyres?
    By plumb bob in forum The Commercial Range
    Last Post: 19-11-2009, 03:58 PM
